Just a taste of what we have instore for the GM Truck systems!
Old Jul 30, 2009 | 03:15 PM
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
Default Just a taste of what we have instore for the GM Truck systems!
After many hours of product design and prototyping we have designed the Nitrous System of the future. The Nitrous Outlet 2010 Nitrous system is the safest, best fitting, and most tuner friendly system on the market. From newly designed solenoids to prefabricated stainless hard lines there is no other nitrous system on the market that can offer the same sexy look and reliable horse power.
Unlike other brand nitrous systems on the market the Nitrous Outlet system is truly a system designed to fit your application. Other companies use universal solenoid brackets and have sloppy looking braided hoses lying all over the top of the engine. The Nitrous Outlet system comes with application specific hardware so that you will not have to order special fittings or different length hoses for a custom looking install. In return you get the best fitment with out the universal sloppy look.
Our 2010 Camaro System includes the following Features.
1. Newly designed high flowing solenoids built to work with today’s fuels.
2. The highest flowing, best atomizing and best fitting Nitrous Plate available!
3. Custom designed solenoid mounts.
4. Prefabricated Stainless Hard lines.
5. Precise fitment fittings.
6. CNC machined fuel feed with Prefabricated Hard line.
7. TPS extension Harness.
8. Neatly hides away under factory engine cover.
9. Bolts on using all factory equipment. (Including cold air box)
10. Wide range of accessories to work in conjunction with our nitrous system.
11. Capable of supporting Horse power levels up to 400 HP!
Wide Range of Bolt on Nitrous Accessories!
After we carefully designed our Nitrous system we did not stop there. Here is a list of our 2010 custom accessories.
1. Cup holder Nitrous switch panel.
2. Console Nitrous switch panel.
3. Custom bottle mount that will let you install your bottle with out drilling any holes in the car!
4. Dedicated fuel system’s
5. Billet heater to work in conjunction with our billet bottle mount.
We are currently taking pre orders and will be able to ship as early as the first week of August. (Next week)
Sale is good for the month of August. Expires 08-31-09
You can place your order by calling 1-866-648-7637 or 254-848-4300
Special introductory price is 599.00
Thank you for your support.
Nitro Dave
Note: All pictures posted are taken during proto typing and fitting. Final products will be anodized and plated.
Nitrous Outlet's 2010 IOM RS SS 6 speed Project car.
Under the hood Prototype installation.
All fuel fittings will be anodized and No brass.
Still fits under Factory engine cover for stealth mode.
Custom Bottle Mount with Billet heater cradle
Bolts in using factory locations and requires no drilling or cutting on the car. Installs and removes in seconds.
Look closely and you will see our billet heated bottle cradle specifically made for the 2010 Camaro. Works with 10lb and 15lb Bottles
(Final Product is anodized Black)
Stay tuned for a post with a full line of our accessories at a special introductory price!
Dave
Old Jul 30, 2009 | 04:01 PM
charcoal03silvy's Avatar
Old Jul 30, 2009 | 05:30 PM
fastnblu's Avatar
I read the title, thought I see a Truck System. Then it shows a Camaro.
Old Jul 30, 2009 | 05:34 PM
Thats because we are not finished with the Truck system. The purpose of the post was to show you we are building true bolt on systems and the GM truck is being developed as well.
Dave
Old Jul 30, 2009 | 05:54 PM
Here is another example of the styling we are going for.
98-02 F-body.
Note: These pictures are from Mock up. Finished products will be anodized. Installed pictures will be posted later.
Old Jul 30, 2009 | 06:27 PM
fastnblu's Avatar
Dave
I hear ya. I just got excited. So is this gonna go back to say 04 & further, or just the NNBS trucks?
Old Aug 1, 2009 | 06:17 AM
05RST2NV's Avatar
Thats badass cant wait to see the truck kit!
Old Aug 3, 2009 | 12:39 PM
04 will be covered..
Thanks guys..
Old Aug 3, 2009 | 01:21 PM
thunderwagen's Avatar
Are you going to offer retro fit kits for those of us that already have your kits. I.e. The hardliners and brackets?
