Jet questions
Old May 14, 2011 | 07:38 PM
charcoal03silvy's Avatar
Default Jet questions
The HSW narrow Flare jets fit NOS nozzles right??
Based on RWHP, not at the crank
Shot Nitrous Fuel
50 .037 .019
75 .045 .023
100 .052 .027
125 .057 .029
Do those seem right?
Also, HSW doesn't have the 19, 23, 29, 45, 52, or 57. WTF?!
Old May 15, 2011 | 04:25 AM
LS1TRUCKGUY's Avatar
the narrow stem jets should fit. as long as the tapered end of the jet seals against the hose fitting you should be fine. i have several different brands of jets i use in my hsw plate without issues, but mine are the wide stem. that sounds pretty close onthe jetting. heres the hsw jet chart for comparison http://www.harrisspeedworks.com/inst...=12&fullsize=1
Old May 15, 2011 | 09:33 PM
bump...
Old May 15, 2011 | 09:43 PM
What shot are you going to start with? I started with the reccomended hsw jetting for a 100 shot and ended up with a 29f jet for 11.8 afr
Old May 15, 2011 | 10:55 PM
Going to start with a 50 or 75 shot till I know its working well and then move up to 125 maybe 150. I don t have a wideband so I'll be reading the plugs. Jets are freaking expensive!
Old May 15, 2011 | 11:21 PM
They get expensive quick... I pay $5 a piece at my local speed shop. I probably have $50-60 just in odd size fuel jets
Old May 15, 2011 | 11:22 PM
I need to get a wideband as well...
simman22
Jan 21, 2017 10:27 PM
natejk
Nov 15, 2016 08:05 AM
1slwgto
Oct 1, 2015 01:51 PM
projectnightcrawler
Sep 30, 2015 10:49 PM
carid
Sep 10, 2015 09:07 AM
