nx express stand alone
Old May 17, 2011 | 07:34 PM
6789olds's Avatar
Default nx express stand alone
is anyone running one of these ? http://www.summitracing.com/parts/NEX-15009/ are they reliable ? what kind of stand alone kits are you guys running ?
Old May 18, 2011 | 05:07 PM
slowswb's Avatar
06chevy5.3 had one it worked great but people look at you fun at the gas station filling it up.
Old May 18, 2011 | 09:59 PM
Bad00silverado's Avatar
running one from trick perf. little bit cheaper and works flawless sofar
Old May 19, 2011 | 01:14 PM
1990LSx's Avatar
Banned
does that NX fuel cell have a fuel pump in it? I see a hot/ground so I figured it must have a pump inside especially at 395$
Old May 19, 2011 | 01:30 PM
TrickTurbo's Avatar
Truck Sponsor
Tank really is not set up for our trucks. Its a low pressure set up, so you would need all new jets and jetting if your nitrous system is a hi psi. Not sure it will fit unless putting it in the battery tray and moving the batter else where.
This is the hi pressure one.
http://www.summitracing.com/parts/NEX-15004/
let me know if I can help you pick a proper tank for your application.
Old May 20, 2011 | 11:52 AM
sprayedenali's Avatar
nitrous. outlet.
walledition
Feb 24, 2026 03:27 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
redbird555
Sep 30, 2015 09:28 AM
MA$TER_E
Sep 9, 2015 03:14 PM
