I need facts not suggestions
Yea, just remember, that 4l60E is going to go out eventually when you build for performance. Some guys have had their go out nearly stock!
Just be aware that while nitrous is as safe as N/A when done properly, adding enough power to any stock transmission will eventually have its affects on it!
-Lurius
-Lurius
Originally Posted by tarinitup
you need a nitrous kit with Fuel pressure safety switch, 100 shot or less, nitrous tune, and window switch if you want to make the tranny last a while longer.
Originally Posted by chevyboy17
What all do I need for my rcsb 4.8 with 4l60e to run nitrous without blowing to peices.I need facts from people with nitrous kits not people with ideas or think they know.
4.8 100shot with a good kit, window switch and Fuel pressure saftey switch and you will have fun.
Remember to swap out the spark plugs to ngk Tr6.
thanx alot for the information guy's.I want nitrous cause at the moment im on a limited amount of money and need a quick fix.I want a 100 shot.I have so many questions about nitrous but am a little scared about who I ask cause all the people who "know it all".Is it really hard to install?
Best of luck!
-Lurius
all you need minimal is a nice kit (wet IMO), ngk tr6 plugs, and a good tune. everything else is optional but recomended. IE: window switches, FPSS, nitrous filters, bottle heaters...the list goes on. you can spend a huge chunk of change getting a nitrous system setup the way you want it.
