HSW plate kit W/throttle cables
Old Dec 6, 2007 | 10:58 PM
sixltrbtr's Avatar
Default HSW plate kit W/throttle cables
Is anyone running the HSW plate kit with throttle cables? Is there an adapter for the trucks to move the cable mounts forward?
Old Dec 7, 2007 | 07:37 AM
silver-mod-o's Avatar
Hunt&Fisherator
is there a problem with them hitting the hoses or brackets???
Old Dec 7, 2007 | 10:41 PM
sixltrbtr's Avatar
Since the HSW plate mounts between the intake and the throttle body it requires the bracket that holds the throttle cables to be moved forward the same distance that the plate adds.
Old Dec 7, 2007 | 11:11 PM
dirt track racer 81's Avatar
i think theres enough slack in the cables for this..people run tb spacers all the time
Old Dec 8, 2007 | 10:55 AM
Onetogofast's Avatar
I know the poweraide TB spacer comes with cabel mount relocating brackets. They are really simple looking you can probably just make your own.
Old Dec 8, 2007 | 04:50 PM
sixltrbtr's Avatar
I can modify the original but if I decide to take the nitrous off I'll need to go back with an original bracket. I've got one coming from HSW. We'll see how it looks. If not I'll try to get one from a salvage yard and do some cutting and welding.
Old Dec 16, 2007 | 03:41 PM
Derek @ EDO's Avatar
FormerVendor
There ya go
Looks pretty good!
Old Dec 16, 2007 | 03:45 PM
sixltrbtr's Avatar
Thanks, I haven't put it on yet but should work fine after a coat of paint.
5.3Caprice
Nov 7, 2015 08:56 PM
maxspeed05V
Aug 12, 2015 06:29 PM
lycominghunter
Jul 29, 2015 04:24 PM
BerryWS6
Jul 19, 2015 06:03 PM
