hsw dry nitrous kit
Old Mar 24, 2011 | 09:21 AM
kalebm22's Avatar
Restricted User
Originally Posted by custm2500
The eBay dealer? If so take it as a sign from the performance gods and buy a proven reliable window switch. I paid $100 for my used msd. I can't figure you are getting that non adjustable junk for much less then that anyhow.
no im talking about harris speed works, they canceled my order. if there was a used msd her for 100dollors ide buy it but there isnt. but all ide do with the msd is set it at 3200 to 5800 and leave it. its not my drag car so im not worried about everylast 10th. i want it to be plenty safe and easy to use. i have everything adjustable on my trans am but i dont want to have to learn my settings on two vehicles, it gets confusing. so if this doesnt work then im out 40 bucks and its not like it will hold the nitrous on and blow my motor lol
Old Mar 24, 2011 | 12:15 PM
custm2500's Avatar
Ph.D. in HUBRIS
Found a few for sale on ls1tech.
Not sure why Harris speed would canceled the order. Call them they should answer the phone they always have when I call.
Old Mar 24, 2011 | 08:41 PM
Steve-O-08's Avatar
I use a Nitrous Outlet WOT/Window switch, it's adjustable. Never had an issue with it. I did have a problem with my Interface shipping with the wrong harness. But no problems with the Interface it's self. I'm not sure about the ebay switch.. I know you knew someone with one, but still... keep your fingers crossed. I would definitely recomend Nitrous Outlet for any of your parts. Too bad they don't make their own verson of the interface.
Old Mar 24, 2011 | 09:19 PM
kalebm22's Avatar
Restricted User
ive called them several times and they finally called me back this afternoon, they said that the kit was on backorder. im also not a very big fan of msd stuff after owning an lt1 lol. i will hopefully have this kit ordered by the fifth if everything goes right.
Old Mar 25, 2011 | 12:40 AM
Steve-O-08's Avatar
You can just buy the kit from N.O. They might be able to get it out to you faster.
Old Mar 25, 2011 | 06:46 AM
custm2500's Avatar
Ph.D. in HUBRIS
Why are you wanting dry? I am sure they have a wet kit in stock. There is a reason the dry is probably on backorder. Most guys run wet therefore that is what they stock.
Old Mar 25, 2011 | 11:31 AM
kalebm22's Avatar
Restricted User
nitrous outlets kit is much more exspensive than hsw, and im running a dry kit because it is cheaper and much easier to hide. i dont want to run another fuel line and try to hide the solenoid and that big nozzel. with a dry shot noone will ever know i have it. the kit will be activated by pluging a connector into the 12v receptical like its a radar detector or something.
Old Mar 25, 2011 | 02:30 PM
Steve-O-08's Avatar
The Nitrous Outlet single nozzle dry kit and the Harris single nozzle dry kits are both the same price.
http://www.nitrousoutlet.com/catalog...3&product=3999
http://www.harrisspeedworks.com/prod...cat=138&page=1
Old Mar 25, 2011 | 04:50 PM
custm2500's Avatar
Ph.D. in HUBRIS
I understand the wanting to hide it! Certainly easier to hide on line and noid vs. two and a larger nozzle.
Old Mar 25, 2011 | 05:30 PM
Steve-O-08's Avatar
That was my reasoning. Plus I like th concept of a dry system. I know countless guys are running wet kits without problem, but I like the ability to control air fuel delivery via my interface and one jet. I feel that a dry kit is safer, but that debate will go on forever. Everyone's got an opinion haha.
