hsw dry nitrous kit
ill be getting the hsw dry nitrous kit with bottle
bottle heater tr6 plugs what is a good window switch that is pretty cheap that works on our trucks? will the mallory window switch work? im goin to activate the nitrous at 3200 and shut it off at 5800, probly be a 100rwhp shot. tuned by nelson for the spray any other suggestions? |
if your running a dry, i would suggest using harris speed works interface to adjust the fuel side a little bit so you dont run it lean ! and i love my micro edge for my window switch.
Originally Posted by badass05chevy
(Post 4666248)
Nice to see someone else running a dry kit! I have an HSW/Nitrous Outlet set up myself, I'm running the Interface with my kit. Nozzle mounted after the MAF sensor. Still need a bottle heater for mine. I had a problem with some HSW parts and I really wasn't getting any help from their customer service people so went to N.O. and they are setting me up with the parts I need. Still need to get the kit back togethe,
Originally Posted by Steve-O-08
(Post 4666309)
Originally Posted by kalebm22
(Post 4667592)
i actually found a custom window switch on ebay that im goin to try out, it is pre programed to turn on at 3200 and shut off at 5800. .
Hopefully it works out for you but I would STONGLY reconsider you intent to buy an ebay window switch. |
Originally Posted by custm2500
(Post 4667775)
Good luck but I wouldn't buy a window switch you cant set. I would also be scared to buy an electrical part like this on ebay and trust it to controll my nitrous set up.
Good luck. At least you have a friend without issues so you aren't the Guinea pig.
ya, but i just checked my order status on the kit and it said they refunded my money and cancled my order. there was no explenation and i cant get ahold of them. im pretty iritated with them now, makes me want to shop with another dealer. but their is a hold on the money right now so idk wat to do
The eBay dealer? If so take it as a sign from the performance gods and buy a proven reliable window switch. I paid $100 for my used msd. I can't figure you are getting that non adjustable junk for much less then that anyhow.
