How will this cam work with nitrous?
Old Oct 25, 2006 | 12:02 AM
99Silverado5.3's Avatar
Originally Posted by Sport Side
There's no reason why this cam wont make power with nitrous...
So, if a stock 5.3 cam (190/191-114) can produce 100rwhp off of a 100 jet, what is really going to stop you from achieving the same results despite your 'reverse split' camshaft? The answer is nothing.
For off an on N2O usage, cam for all-motor and let the N2O/FUEL jets decide the power levels. If you want more power, put some bigger jets in. Opening up the exhaust can also help if you are restricted on this side of things.
...I wouldn't worry about getting a nitrous cam, get a cam thats runs great all motor, so on spray it runs even better. Unless spraying like 150 shot or more there won't be much a difference between a regular aftermarket cam vs. a nitrous one.
Old Oct 25, 2006 | 02:51 AM
FarmerBeau's Avatar
Sexy Party Mod
Thats exactly what i would say. Get that motor running badass NA and then go to nitrous. Choosing a cam around Nitrous is foolish IMO. Are you going to compromise your NA power for Nitrous power. Simply get all you can out of your NA setup then add the proper jetting to get you where you WANT to be.
ARC
57
Feb 21, 2022 10:54 AM
Castro45
24
Jul 31, 2015 07:13 PM
Suburban2500
Jul 19, 2015 04:50 PM
06 4.8
Jul 15, 2015 07:17 PM
4B11T
Jul 13, 2015 03:48 PM
