How much can i spray??
Old Jan 6, 2009 | 09:22 PM
DABLUE's Avatar
Default How much can i spray??
I got a 5.3 tuned . an im thinkin on spraying a 75 shot but i dont know if its safe cuz it aint tune for nitros !!???? help ???
Old Jan 6, 2009 | 10:18 PM
brobradh77's Avatar
I believe up to a 125 shot is fine with out retarding the timing...so either way 75 and you should be fine.
Old Jan 6, 2009 | 10:56 PM
DABLUE's Avatar
oh okay so maybe 100 shot would be good
Old Jan 6, 2009 | 11:03 PM
sixltrbtr's Avatar
Go BIGGER!!!
Old Jan 6, 2009 | 11:17 PM
00ChevyScott's Avatar
Wearin' da big hat
It's got an N/A tune, I wouldn't spray over a 50 shot without contacting your tuner.
Old Jan 6, 2009 | 11:18 PM
TXsilverado's Avatar
i wouldnt spray at all without a new tune.
Old Jan 7, 2009 | 04:21 AM
aksz71's Avatar
false on the 125 shot without retarding ,cause mines not tuned and i hit knock with my 125 but thats all fixing to change... 100 shot on a regular tune depending on the advancement. stock tune 100 no problems.. 125 get a tune...
Old Jan 7, 2009 | 08:20 AM
Nick@HSW's Avatar
FormerVendor
It depends. I would call your tuner and see if your timing was advanced any. Another option is to use a device that will only pull timing while spraying such as the Interface. Feel free to shoot me over a PM if you have any questions. Thanks!
Nick
Old Jan 7, 2009 | 12:33 PM
brobradh77's Avatar
I have been told other wise but my set up may have been different.
Old Jan 7, 2009 | 06:25 PM
charcold-bowtie's Avatar
I sprayed a 125 shot on a W4M NA tune. Probably a bad idea tho.
