hooking to streeing
Old Sep 11, 2009 | 07:40 PM
speeedo's Avatar
Default hooking to streeing
hi guys
any one have any ide how i can hook the nitrous button to the streeing wheel ?
are there any special bracket that i can use ?
Old Sep 11, 2009 | 09:40 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
why not just get a pedal switch? or an arming switch and a pedal switch?
Old Sep 11, 2009 | 11:19 PM
aksz71's Avatar
x2 simplest and easiest way.
Old Sep 12, 2009 | 12:34 AM
SilverDog's Avatar
Fast and the Furius
Old Sep 18, 2009 | 03:27 AM
jmill96Z's Avatar
10 Second Club
LOL Hook that **** into your horn. I'm seeing it now. You flying down the strip with the horn blaring
Old Sep 18, 2009 | 07:54 AM
TXsilverado's Avatar
and most safe
Old Sep 19, 2009 | 08:53 PM
PappyDan's Avatar
Tribe Shaman
what can i say, i like to push the damn button
Old Sep 20, 2009 | 12:50 PM
fastlt1's Avatar
12 Second Club
So you are going to just use it as a arming switch, correct. You are still going to use a WOT switch and window switch, correct.
Old Sep 22, 2009 | 09:50 AM
mitch cobb racing's Avatar
i think what hes saying is he will have an arming switch and then he wants a button on the wheel instead of aWOT switch under the pedal. easy enough, just wire in the button instead of the WOT switch and mount it however you can. alot of people that use a button just keep is lose and hold on to it.
Old Sep 22, 2009 | 03:56 PM
speeedo's Avatar
what i`m asking is same Fast and the Furius are there any bracket to mount the arming to the wheel
