hidden setups.
Old May 19, 2006 | 10:36 PM
goshawk23's Avatar
Truck addict
but then it isnt as hidden...i like how it comes out the back, just not in the mood to modify to make it fit when i can just stuff the nozzle into the egr
yea but this plate sprays so much better. it's worth the little bit of time it takes
Old May 20, 2006 | 01:10 AM
i have always thought that if i ever sprayed i would mount the bottle inside the frame. seems like a good place to put it
Old May 20, 2006 | 10:05 AM
dry_kill's Avatar
I'm don't know much about N20 but check out daves outlet sit and look at the money maker, or go to ls1tech.com and do a search for money maker, he hides everything inside the manifold, its 850 bucks and can spray up to a 250 or 300 shot, I can't remember too well
Old May 20, 2006 | 11:24 AM
TXsilverado's Avatar
yeah ive seen that...its pretty crazy. damn expensive though
Old May 20, 2006 | 01:54 PM
TchargedLS1TA's Avatar
Give Dave at Nitrous Outlet a call. If you're familiar with the MoneyMaker for the LS1's, he can do pretty much the same setup for the truck intake as well.
Old May 22, 2006 | 04:08 PM
nonnieselman's Avatar
Nitrous Stuff has been "ordered". I cant wait to get it! Im like a lil kid at Christmas time! hahah
Ill have some nice pics for you guys...
Old May 24, 2006 | 07:00 PM
Can i use a regular NOS solenoid to use for a Purge noid? Ill have an extra one. so i was just wondering?
Old May 24, 2006 | 07:17 PM
goshawk23's Avatar
Truck addict
yea you can
Old May 24, 2006 | 08:00 PM
Thanks Goshawk!
Old May 30, 2006 | 10:12 AM
i got this complete wet kit for $370.
4 NOS solenoids
On/Off switch
Full Throttle Switch
Fuel Pressure Safety Switch
2 nozzles
1 set of nozzle lines
1 set of Jets (150 Shot)
2 bottle feed lines
Bottle Heater
20lb Bottle w/NOS high flow valve
5lb Bottle
Only thing i have to get now is some more wire and a Window Swtich.
Does ANYONE have pics of their kit installed?? I would like to see where all the lines and wireing is ran. Where the bottle is mounted and how its mounted. Where the switchs are mounted.. All that kindof stuff..
Im goin to get pics of my install to hopefully help some other guys...
Thanks!!!!
