hidden setups.
Old May 19, 2006 | 09:23 AM
nonnieselman's Avatar
Default hidden setups.
Kindof a stupid question, but do any of you guys have a very clean hidden Wet shot??
When i get my kit, i want to have it hidden as best at possible.
Can the Noids be put under the intake cover? i plan on running the lines in Loom and keeping everything run along the factory wiring in loom.
Now the next big question. where should i put the bottle? I like the look of a guys set up on here(a blue RCSB), he has the bottle in front of his rear passenger tire. I dont really have room to spare to put it in my extended cab part. I have a soft toneau so possible i could put it back there? What i was thinkin would be the sneakest place is under the truck along the frame rail or maybe mounted to the body possibly?
I have some work cut out for me...
but it will be worth it. sneaky, sneaky...
Thanks guys!!
Old May 19, 2006 | 10:58 AM
goshawk23's Avatar
Truck addict
look at this thread...
https://www.performancetrucks.net/fo...s+outlet+plate
i have a few more things to do to clean it up even more. basically i have a three piece cover that will hide what isn't hidden already.
Old May 19, 2006 | 11:49 AM
thanks goshawk, that looks awesome.
its goin to be a lil while before i spray, i just want to get everything installed first.
you think about puttin wire loom on the lines? and where it connects to the fuel rail? it would look factory to most people, and they would pay it no attention.
Old May 19, 2006 | 12:52 PM
slowprocess's Avatar
I'll get some pics of mine on my truck. It's all but spotless under the hood. Especially since I'm going into the egr hole, which is conviniently located under the engine covers.
Old May 19, 2006 | 12:57 PM
TXsilverado's Avatar
didnt know you could go through the egr...i figured the spray wouldnt have enough time to get spread out being that deep into the intake system...
Old May 19, 2006 | 01:42 PM
it seems like the EGR hole wouldnt work all that great. wouldnt it miss #1 cyl? opposed to about midways of the intake tube? where it should be spread out and filling the whole intake tubing?
Old May 19, 2006 | 01:54 PM
have they redesigned the nitrous plate yet so we dont have to modify the intake any?
Old May 19, 2006 | 04:29 PM
LS1TRUCKGUY's Avatar
THERE IS ANOTHER GUY ON HERE THAT HAD DAVE MACHINE THE NOZZLES ON THE SIDE OF THE PLATE INSTEAD OF THE BACK. PRETTY TRICK IF YOU ASK ME.
Old May 19, 2006 | 07:34 PM
goshawk23's Avatar
Truck addict
spraying through the egr hole is perfect setup. our intakes are nothing like the fbody's. we have a hole in the middle that all air must travel through before it reaches the cylinders. which makes it ok to spray into the egr hole. it's quite nice.
i do plan on wrapping everything on my setup with tape or wire loom. either way, when i get around to cleaning up the engine, all nitrous stuff gets hid. permantly
Old May 19, 2006 | 08:42 PM
but then it isnt as hidden...i like how it comes out the back, just not in the mood to modify to make it fit when i can just stuff the nozzle into the egr
