Go for the 150
Old Aug 3, 2005 | 07:39 AM
Fogle07's Avatar
had a 125 on mine and sprayed it thru the shifts. tranny hasnt blown yet. but im sure it will if i keep driving it how i do. if the motor dont go first
Old Aug 3, 2005 | 07:41 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I am going to set my up to shut off the nitrous at 5900 right before the 6000 shift and come back on right after the shift. There might be a couple thousandths lose but thats it and worth it IMO to make the tranny last longer.
Old Aug 3, 2005 | 08:13 AM
oxidizr's Avatar
Moderator / Sponsor
For our GM platform trucks ....
125-175 RWHP (150-200 shot) is the tuner zone. Stock componets will hold the power with consideration for tuning and other upgrades are a must. PDM / Driveline / Motor Mods are must to maximize these settings. Expect drive line failures unless pasts are upgraded.
100-125 RWHP (120-150 shot) is the safe zone for fairly stock trucks with sub 100K on the odometer whose intention is speed. Some longevity of Stock parts will be sacrificed (G80's, 4L60E's)
75-100 RWHP (100-120 shot) is a good street setting for stock trucks with sub 100k and consideration for longevity of parts
upto 75 RWHP (under 100 shot) is a safe beginer zone to learn nitrous and get a feel for how it works will little or no adverse effects on driveline and some room for error.
Window swiches do help reduce trans wear.
Progressive Controllers help with traction.
100 rwhp or more and look towards:
1.) a converter if you want maximum shift extension and off the lien performance
2.) tires to support dramatic torque increase
3.) shift kit with transmission tuning
4.) replacement center section for G80s
5.) transmission coolers
6.) fuel system monitors / pcm tuning
Old Aug 3, 2005 | 08:37 AM
slowec's Avatar
WELL PUT!!! Maybe you should make that a stickie. Alot of good info for newbie juicers. Driveline failures, could you be referring to my 13k 4l60e rebuild Told my wife it was in the shop for a recall.
Old Aug 3, 2005 | 08:56 AM
1slow01Z71's Avatar
Gotta do what ya gotta do to keep the other half happy. If my gf knew how much money I really spent on my tranny rebuild she would kill me. She thinks I only spent 1500 on the rebuild.
Old Aug 3, 2005 | 03:02 PM
250 shot spraying thru the shifts at 7300. Oh and with 120k on the engine, its still going strong. The stock tranny other than a shift kit unloaded after having the bottle on it for about 30k.
Old Aug 3, 2005 | 03:07 PM
1slow01Z71's Avatar
Originally Posted by BLK6.0HD
250 shot spraying through the shifts at 7300. Oh and with 120k on the engine, its still going strong.
Thats why you have gone through so many trannies.
Old Aug 3, 2005 | 03:10 PM
lol, i was lucky it lasted that long sprayn it out of the hole with the 250 to it.
Old Aug 4, 2005 | 08:32 AM
TigerFan187's Avatar
I dont necessarly think that the truck guys are "scared " to spray 150 its just that most people have the ruek of 150+ you need a new fuel pump. That is conservative as well even though Ive sene people max out their fuel pump ith a 150 shot! Hell my buddy CRAZYCUTER4.8 sprayed 225 shot 30 times probably with no problems and that was on stock pump,stock plugs(he just doesnt give a f*ck-but has changes since then). I think another reason they dont go to 150 is becuase they do the install themselves and dont want to mess with a fuel pump at that time! I have plans for 200-250 shot on the LS1(stock block) in the near future!
Old Aug 4, 2005 | 12:16 PM
slowec's Avatar
For the cooler weather coming, I will either pill past the 150 mark or sell my intake and n2o kit and go forced induction. I will see better times regardlees of neededing to bring a broom and dust pan to the track If I blow the 5.3, it'll just make a good excuse to get a 6.0 sooner
See my nitrous kit!
