GM steering wheel buttons for nitrous purge?
Old Dec 3, 2014 | 11:57 PM
turbodriven04's Avatar
Registered User
Default GM steering wheel buttons for nitrous purge?
Has anyone use one of their steering wheel buttons for a purge button or even an activation switch? I wanting that super sleeper look with nothing out of the ordinary.
Old Dec 4, 2014 | 03:15 PM
askkmb's Avatar
Never seen anyone doing that, but im sure you could build something thatll work. However youd have to modify your steering wheel buttons and somehow build another **** behind it to push it with the stock **** cover. The stock ***** wont work because theyre not 12v, theyre just signal wires.
Old Dec 4, 2014 | 03:24 PM
Atomic's Avatar
I have a gauge for that
A switch is a switch if you dont mind loosing the functionality of the original steering wheel.
Old Dec 5, 2014 | 02:06 AM
Registered User
Right. I just don't use the phone silence button on mine and figured it would be a cool purge button.
Old Mar 31, 2015 | 02:56 PM
Mike454SS's Avatar
It's where I plan to put my transbrake/2-step.
Old Apr 1, 2015 | 12:41 AM
Noah Burns's Avatar
Just have to trace the wire and use it, a buddy did it with a 4th gen camaro for line locks, pretty slick I thought. I lost $0 on the " find the line lock switch" bet lol
Old Feb 1, 2018 | 12:54 AM
jkwalkercchs's Avatar
Year make and model I'll get u a diagram and help u spec it out
Old Feb 1, 2018 | 12:59 AM
Ok so this isn't going to work because that is a resistance circuit. So all those functions are on 2 wires and each button press has a different value
Old Feb 1, 2018 | 01:02 AM
First was an 05 2nd is an 03
Old Feb 1, 2018 | 08:10 AM
Choda's Avatar
I’ve seen it done w Fox bodies and trans brakes
