dry to wet conversion...
Old May 5, 2008 | 10:38 AM
sickREDsierra's Avatar
Default dry to wet conversion...
i am going to do this with my dry kit soon, and i am expecting to drop a few tenths at the track with the same/similar size jets.
i noticed on the dyno that my dry juice is flywheel rated, as i only picked up 75ish of the 100 dry i was spraying...
i am gonna convert to a regular intake jetted style wet kit, with a 100-125 shot...
am i crazy to think that i will gain a few tenths? it should be another 75 or so rwhp, with the 125 wet kit in there, shouldnt it?
Old May 5, 2008 | 05:36 PM
7845's Avatar
Banned
on ls1tech theres a thread that goes on for like 12 pages of wet vs dry....most of that thread is favoring dry
Old May 5, 2008 | 06:15 PM
sharpshooter's Avatar
Dynotune nitrous sells the conversion kit.
Old May 5, 2008 | 06:49 PM
Mangled03gmc's Avatar
Baltimore Whore
Depending on what brand kit ya have, they have conversion kits out, thats what I am going to do with this dry kit I just picked up(HSW). All ya need is a fuel solenoid, a new jet, line.
John
Old May 7, 2008 | 08:54 PM
i wasnt asking if it could be done, or how to do it, i was just asking if i was correct in assuming the conversion would result in a lower timeslip.... with the added horsepower rating the wet kits have over dry.
i do appreciate the compliments though
Old May 7, 2008 | 08:58 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I don't see why (unless you are not getting enough fuel) a dry shot would be any less or more than a wey shot.
Old May 7, 2008 | 09:09 PM
well, the dry is rated at the flywheel , whereas a wet is rwhp rated.... so i assumed if i went from 100 dry (about 75 rwhp) to a 125 wet, i should pick up a good bit at the track... shouldnt i ?
that was my initial question.
Old May 19, 2008 | 11:01 AM
gdev_'s Avatar
Why don't you just up the dry shot? The main benefit of using a wet setup is if the injectors will not support the target HP, other than that, HP = HP for the most part, regardless of if it's flywheel or rearwheel rated.
cheyenne383
Nov 13, 2015 09:24 AM
Chavette
Oct 28, 2015 07:33 PM
03sierraslt
11
Oct 27, 2015 03:38 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Jaz
Sep 18, 2015 09:23 PM
