dry shot to spool
Old Aug 11, 2008 | 08:51 PM
sdimer350's Avatar
Thumbs up dry shot to spool
my buddy has a dry kit for his diesel laying around and i was thinking of hooking it up to my truck and giving her a 70 shot outa the hole to spool the turbo. what ya think and where do i put the nozzle?
Old Aug 11, 2008 | 09:03 PM
nonnieselman's Avatar
Are you Speed Density or Still using the MAF??
Old Aug 12, 2008 | 12:43 PM
sdimer350's Avatar
still using maf
Old Aug 13, 2008 | 06:23 PM
sdimer350's Avatar
what needs to be done as far as tuning to run a small dry shot?
Old Aug 13, 2008 | 06:46 PM
Mangled03gmc's Avatar
Baltimore Whore
Fuel and timing. I would also think about getting a SD tune, a wet shot.
John
Old Aug 13, 2008 | 06:55 PM
Fuel and timing. I would also think about getting a SD tune...
John
Dry Shot and Speed Density tune is a big no no unless you want a new engine...
I have a 50 wet shot on mine with the STS. The 4l80E and stock converter with 3.42s killed my 60'fts. but with the spray it dropped from a 2.3 to a 2.0 spinnin on DRs..
Old Aug 13, 2008 | 06:58 PM
Baltimore Whore
EDIT fixed, I did not know that, back to the books for me on SD basics LOL
John = bonehead
John
Old Aug 13, 2008 | 07:10 PM
John = bonehead
John
Hahah.. well here is a run down for you..
Speed density you are commanding the AFR you want. No MAF at all. I removed mine and put a IAT sensor in my intake pipe.
MAF controls your fueling, If for some reason your MAF fails it reverts to the VE table.
In SD you Manually Fail your MAF so you then fine tune your VE table..
Hope that makes sense.
Old Aug 13, 2008 | 07:19 PM
sdimer350's Avatar
so will my maf compensate for the dry shot if injected before the maf? im stupid about nitrous, never used it.
Old Aug 13, 2008 | 09:24 PM
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
I would personally put a wet system on it.. But if you go dry put the nozzle before the maff.
Dave
