Daves Outlet Purge Install ?
Old Mar 9, 2008 | 02:42 PM
moog5050's Avatar
Default Daves Outlet Purge Install ?
I am installing a new wet kit from Dave's outlet. The nitrous solenoid has two "in" connections on each side and one "out" on the bottom. As I understand it, I can connect the bottle line to the larger "in" connection and then connect the purge on the other side to the smaller "in". Can anyone confirm this?
Also, can I install the fuel pressure shut off switch between the fuel feed line and the fuel solenoid?
Thanks.
Old Mar 9, 2008 | 09:01 PM
TrickTurbo's Avatar
Truck Sponsor
You are correct, on both questions.
Old Mar 9, 2008 | 10:11 PM
moog5050's Avatar
Thanks Rick. I will probably need a longer fuel line from the tank you are building to the fuel solenoid. Can you make one?
Old Mar 10, 2008 | 09:11 AM
TrickTurbo's Avatar
Truck Sponsor
standard is 4ft,,, how long do you need. You actually will be building the line. I supply the fittings and hose. You supply the labor.
Old Mar 10, 2008 | 09:44 AM
moog5050's Avatar
4 feet will do it. The one that came with my N20 Package is only 18".
stealthperf
34
Feb 14, 2016 11:35 AM
The_W
Oct 28, 2015 09:00 PM
Fast86z
Aug 23, 2015 12:35 AM
