Cutting -6 AN line
Old 05-18-2019, 10:31 PM
  #21
I have a gauge for that
Atomic's Avatar
You guys are going to force me to make a video of why to get the hose cutters arent you? -_-
Old 05-19-2019, 05:43 AM
  #22
RySmDPT14's Avatar
Cutters are clean and easy, might leave a few stragglers but Tin snips work to clear those out. I’ve done the cut off wheel method and prefer the cutters as they are clean and less debris to fall into the line.
Old 05-19-2019, 09:08 AM
  #23
LS1TECH Sponsor
Lonnies Performance's Avatar
Hose cutters are great without a doubt & I use them on rubber based braided line all the time.
Where I hesitate to use them is on hoses with a Teflon liner.
They tend to crush & deform the end of the Teflon so in this case I stick to a cutoff wheel.
Old 05-19-2019, 02:49 PM
  #24
arthursc2's Avatar
Received 1,436 Likes on 1,063 Posts
Originally Posted by Patrick05
Hose clamp method left a perfect cut, but how are you getting the hose end on without taking the clamp off and letting all the strands go everywhere?
If you've got 2 hands this will be easy.
Loosen the clamp like 5-10%, just enough to make it mobile on the braid. Get your nut ready, fit nut over hose, begin to install nut. Continue to loosen clamp and move it down while installing nut. 2 hand job, need a vise to hold the hose tho
Once the nut is on, unthread clamp and move to next hose
Old 05-23-2022, 07:49 AM
  #25
Modern Barbarian's Avatar
Something that worked really well for me was heat shrink. slide a piece on, shrink it, and then cut through the middle of the heat shrink. Holds everything nice and tight. then peel it off and put the end on.
zz454Chevelle67 (05-24-2022)
Mean Green z28
04-11-2016 06:56 PM
eddie_da_chevy_guy
07-09-2012 06:35 PM
dowright82
07-09-2004 09:12 AM
TwoFast
12-21-2003 11:04 PM
redaddiction
03-04-2003 07:07 AM
Quick Reply: Cutting -6 AN line
