l92 6.2 oil dipstick hitting coolant line caused line to break!? wtf?
Okay so on a 07 escalade everytime you leave a stop light or WOT you can here a loud tap in the engine bay... and the other day i noticed it had coolant leaking i follow the leak and notice one of the aluminum coolant lines had be worn out by the dip stick hitting/rubbing on it! so my bro and i check it out and when its in Drive and you give it gas the engine and trans shift/lean a big amount to where the oil dipstick taps the coolant lines and you can hear other things under the truck get hit under the truck, by the trans... is there any type of recall out there for this?? Is anyone experiancing the same problem. All you 6.2 guys might want to check it out
the 6.2 is too strong sell it and get a 5.3
motor mount is bad, had this problem with my trucks and 2 friends of mine
mostly denalis and awd/4wd lunches that kill the mounts faster
hope some one makes some serious polyurethane motor mounts for these new trucks
jroctpb
Aug 11, 2015 03:52 PM
ullose272
11
Jul 17, 2015 07:22 AM
