This is Crazy
Old Mar 18, 2008 | 08:41 PM
  #61
getnit1's Avatar
43 bottles and 7820 miles. No problems at all so far. Not a hiccup or anything I have nothing but a wide open throttle switch mounted to the bracket of the gas pedal that it closes when the pedal pushes to WOT and a main arm switch in the bottom of the ash tray. All the electronics are courtesy of General Motors. I hope to get time to run it and see what it will do. I will probably have to get out at the end of the track when the 100 mph shutdown comes in and roll through the lights.
Old Mar 18, 2008 | 09:00 PM
  #62
dirt track racer 81's Avatar
how much you sprayin now??
Old Mar 19, 2008 | 08:29 AM
  #63
Tootall's Avatar
hurry up and get that thing to the track ! . . . before she blows !
Old Mar 22, 2008 | 03:26 AM
  #64
getnit1's Avatar
Well I guess I will never know what it would do now, I traded it yesterday with 7999 miles on it. I did manage to spray the 44th bottle through it. I turned it into a Victory Red Crew Cab 2wd SLT with 3:73 and the LY5 5.3, I just could not pass up the 0% interest for 60 mos. I went ahead and put some of the GM 20" wheels and the Denali tube steps and a spray in liner on while I was at it. 0% on accessories financed with the truck what a deal only in america. I now have to go and get my kit off of my truck and install it on my crew cab and torture test the 5.3. Hopefully I will get a bottle down its throat before the weekend is over. After looking into it I could have got a Denali in 2WD for 2K more as far as the sticker price was. Maybe next time. I will let you know when the CCab is on a N20 diet and how it does. I need to get this first tank of 87 burned out before I spray it though.
Old Mar 22, 2008 | 07:06 AM
  #65
TG02Z71's Avatar
I feel sorry for the next sucker that buy that ticking time bomb!
I still can't beleive it held up that long!! You should have called Guiness book before trading it in.
Old Mar 23, 2008 | 05:29 PM
  #66
i still want to know what solenoid u are using cause i dont think it will support over 150hp and i think that is why it held up so long.
Old Mar 24, 2008 | 03:35 AM
  #67
LMSeven's Avatar
Old Apr 3, 2008 | 07:59 PM
  #68
87FoxBody's Avatar
[QUOTE=getnit1;3782011]Probably more like 200 lbs of nitrous through it if you factor in the partial fills. I am just starting my 4th big bottle which calculates close to 80 lbs per bottle. QUOTE]
I dont see how your getting anywhere close to 80 lbs out of a cylinder I fill nitrous on the side and i have a refill station the most i have ever been able to get out of a cylinder is maybe 50 lbs or so(if im lucky) what kind of nitrous are you runnin? where do you get it? Oh and the stuff we get here only cost about 85 for a cylinder.
Old Apr 3, 2008 | 08:58 PM
  #69
getnit1's Avatar
I was getting the cylinders from Tex-Air. It was the Nitrous+ with the siphon tube. Generally the med grade comes in a 50lb bottle and does not have the siphone tube they are about 14 inches shorter than the cylinders I was getting. The bottles I use to get were over 5 feet tall.
Old Apr 4, 2008 | 11:28 AM
  #70
87FoxBody's Avatar
I get the nitrous plus and the difference in the full weight and the empty weight is only 52 lbs.
