This is Crazy
Is there a way to take the jet out completly and spray that way, if you have to new motor, fu** it, see if shell hold then, get it on video though. Cant believe shes still going strong, that just says what these motors are capable of.
If you don't give a f, bypass the solenoid and straight hose from bottle.
Ok I am at 28 10lb bottles now. I need to pick up another fill cylinder this will be the 4th plus I had the bottle filled 9 times before starting to fill my own. This is getting expensive. Crack would be a cheaper thrill. I will try a larger solenoid mine is rated at 175 but I can tell a difference between the 63 jet and the 71 jet. The tires brake loose 90% of the time under 40 mph with the 71 and seldom with the 63 unless at low speeds with a downshift.
. I wana see the aftermath of that explosion, aleays wanted to see a head come off, or at least a huge flame come out from the hood.
