anyone use the fjo mini controller?
Old Jul 20, 2006 | 04:30 PM
goshawk23's Avatar
Truck addict
Default anyone use the fjo mini controller?
i just got mine in the mail today and was trying to figure out how i want to set it up. such as ramp up rates.
50 percent at wot then 2 seconds later 100 percent.
Old Jul 20, 2006 | 07:56 PM
blacksheep's Avatar
Good luck I have not had good luck with them.
Old Jul 20, 2006 | 08:19 PM
goshawk23's Avatar
Truck addict
why is that curt? going by others it seems to be a good unit. tell me your experience
Old Jul 20, 2006 | 09:28 PM
NXRICKY's Avatar
Former Vendor
The unit is the best with rampings available to you... This is the way I set them up IF the vehicle spins with a full hit from the get go on the bottle.
Starting with launches...on NON ideal platform, stage 1.
SET the line straight across lets say 50% for exp. Launch the vehicle. spin yes or no
if yes decrease % until tire stops spinning,
if no up the % keep doing this until you just start sqeeking the tires and then back off 20%. Now from that point ramp to 100% over a 5 second time line.
Launch and see what happens. tire spinning yes or no
Yes increase ramp time, no decrease ramp time. just until the tire starts to spin a little, add a smedge of time and that part is done. You have just set up the base line for the best traction under NON-ideal platform. Now why back it down 20% earlier, to give a nice window for NON spinning launches. The time decreasing will off set that little issue.
NOW repeat for stage 2. for IDEAL platform, like at a race track.
once that is done a simple wiring diagram with the additon on another toggle switch, TO switch between stage 1 and stage 2, or Crappy road setting, and NICE race track setting. and no more computer is needed.
Let me know if you want it, I them on file at the office.
Hope this helps
Ricky
Old Jul 21, 2006 | 07:21 AM
slowprocess's Avatar
Goshawk if you really need to do the swap on those noids to pulse, just let me know. We'll work something out.
Old Jul 21, 2006 | 09:11 AM
goshawk23's Avatar
Truck addict
thanks a lot ricky. so i can switch if for street and strip. i like that method of approach as far as setting up the ramp times and such. i'll be posting back
Old Jul 21, 2006 | 09:28 AM
NXRICKY's Avatar
Former Vendor
Old Jul 21, 2006 | 09:21 PM
litreddevil's Avatar
Banned
so how much r these thing looks like i might get one
Old Jul 21, 2006 | 09:43 PM
goshawk23's Avatar
Truck addict
200 @ nitro daves
Avalanche2002
Nov 30, 2015 07:31 AM
turbo6c3
Oct 5, 2015 06:11 PM
old motorhead
Sep 29, 2015 08:22 PM
