Anybody run TR7s with large shots?
I installed the 6's from the get go and my motor seems to run O.K. I have some 55's on the shelf I may install when I get around to it as I want to see if there is a noticeable difference in NA form. Haven't sprayed yet but do have it pilled for a 200 shot. I have been kicking around installing another nitrous kit with say a 75 shot and pilling the direct port down to a 100 shot for the time being. More than likely I will start with the TR-6's and only spray in 3rd gear (2 second progressive ramp after the shift) and pull the plugs to have a look-see.
Built408, Do you have any EGT numbers to share in relation to shot size? I never gave EGT too much of a thought but now you have me curious just like ZR1 Dreaming.
Also, where are you guys buying the TR-7's? My local auto parts store looked at me sideways when I said I needed them. I was suprised they didn't carry them. Looks like an internet purchase...
Ok thanks blacksheep, good to know. I was a bit skeptical of jetting that high with my CR and only running pump gas.
...unless I'm missing something and they rate each stage on the plate kits for a 200 shot...
So when your standalone is done how are you going to run the big shot? I read you want to run 175 without the standalone, but what are you going to do for the other 75? Reason is I'm thinking about running a dual stage plate conversion from N20 Outlet and I'm assuming that's what you have.
Noah Burns
Sep 7, 2015 05:50 PM
ZO6Ted
Aug 12, 2015 07:50 PM
