Advice on installing nos
Old Oct 20, 2014 | 03:32 PM
Offroadunleashed's Avatar
Default Advice on installing nos
Going to be installing some nitrous on my 06 chevy 5.3 comp cam xr269hr, cai, exhaust with lts. Trans is slightly built. Larger pump, higher shift pressures, etc. what kind of wet shot can I put in with stock plugs and tune and what can I use with changing some stuff? Here's the kit: http://m.summitracing.com/parts/zex-82047
Old Oct 21, 2014 | 06:05 AM
BLKSSLTT's Avatar
formerly turbo4.8 (2014-06-25)
You don't want zex products. A nitrous express proton lot would be sufficient for you.
Old Oct 21, 2014 | 01:51 PM
Nitrous Express's Avatar
Former Vendor
The Proton Plus Drive by Dwire system would be a direct bolt on for you and will flow 150hp straight out of the box, and can flow up to 250hp with a few extra parts.
PROTON FLY BY WIRE NITROUS SYSTEM W/ 10LB BOTTLE
Old Oct 26, 2014 | 10:51 PM
Thanks for all the advice.
Old Oct 29, 2014 | 06:31 AM
Noah Burns's Avatar
you have a cam in that 5.3 and you're wanting to spray it, all on the stock tune? I'd suggest you invest in a tune, a real tune, not a hand held, before you go to spraying it...
Old Oct 29, 2014 | 08:48 AM
I have a zippy tune
Old Oct 29, 2014 | 09:57 AM
porksoda's Avatar
There is a lot wrong here. For one you don't want to run stock plugs with nitrous. You want to go a step colder and use copper tip plugs. No platinum or iridium. Also as mentioned you will want to get a real tune for nitrous. COntact Zippy and tell him you will be using nitrous so he can adjust it. Common rule is per 50 shot to pull timing.
ARC
57
Feb 21, 2022 10:54 AM
The_W
Oct 28, 2015 09:00 PM
Blackrat48
Aug 16, 2015 11:56 AM
sauldgold
Jul 23, 2015 02:15 PM
