75 shot with stock plugs?
Old Feb 7, 2011 | 05:37 PM
fastrt's Avatar
11 Second Truck Club
Default 75 shot with stock plugs?
I was wondering if some of you had ran a 75 wet shot on stock ngk tr55's. I have heard of a few. I am just toying with the idea so I can still use my kit, and go fast on a stock ish trans. I can pull some timing too, but have heard most dont do anything with a 75 shot. not looking for you should do this or you should do that, just want to hear from those who have done it. I may do a 50 shot just to toy with.
Last edited by fastrt; Feb 8, 2011 at 11:57 AM. Reason: clear up what I was asking.
Old Feb 7, 2011 | 05:39 PM
Mangled03gmc's Avatar
Baltimore Whore
I have read some people going to 1 step colder, but alot are keeping stock plugs
Old Feb 7, 2011 | 05:55 PM
matt29201's Avatar
i have run a 150 shot on tr55s and had no troubles. even checked them a few times and found the plugs burning clean and no sighn of burnt tips
Old Feb 7, 2011 | 05:58 PM
fastrt's Avatar
I was even thinking about a 50 shot just to play with. I asked about hp and trans swaps with a GTO hot rod tech/buddy of mine, and he said 500 to the flywheel is the tops. I bet my setup with 50-75 shot would be ok.
Old Feb 7, 2011 | 06:55 PM
matt29201's Avatar
oh yeah i wouldnt hesitate to hit it with a 75 shot
Old Feb 7, 2011 | 07:08 PM
2007chevy5.3l's Avatar
Youll be fine with stock plugs with that small of a shot
Old Feb 7, 2011 | 07:45 PM
00buckshot's Avatar
DO it. 75 is a baby shot! You'll be fine, I used to run 150 on stock plugs
Old Feb 7, 2011 | 07:56 PM
matt29201's Avatar
thats right!
Old Feb 7, 2011 | 08:45 PM
fastrt's Avatar
ha ha. I ran non projected 6 heat range for my 100 shot. and pulled 3* timing. thats why I ask.
Old Feb 7, 2011 | 09:24 PM
custm2500's Avatar
Ph.D. in HUBRIS
It is $2 dollars per plug. It is also huge insurance. You will probably be just fine, but you are defiantly foolish to not spend $20 or so to give your self a huge advantage that you won't detonate and blow your motor to hell.
A step cooler plug won't hurt your N/A power and at a 75 shot you could run the stock timing, cooler plugs, and some high octane.
Personally I run a fairly aggressive tune(BB performance 93 octane tune), 100 shot, 1* cooler plugs, and 110 when I am spraying.
I wouldn't skip $20 in plugs no matter what shot I was running.
