410 gears w/125 shot?
Old Jul 19, 2009 | 11:15 AM
GSXRider08's Avatar
Default 410 gears w/125 shot?
I have a question for everyone running spray on a 5.3. Im runnin a 342 gear rite now. Want to switch over to 373 or 410, witch would be best? Im running 22's w/ a 2-4 drop so my wheels are 82.5lbs a peice.
Old Jul 23, 2009 | 10:00 AM
walledition's Avatar
im running 20`s with 4.10`s and well the mastercraft tires arnt the best anyways but im just spinning, but if i run 17" with hankook tires wish have more traction then the 4.10`s are a blast, at least for a daily driver
so i would say switch to 4.10`s
Old Aug 21, 2009 | 06:46 PM
Serrano454's Avatar
is this a DD cuz if it is go 4:10s if not i would say go 4:56's
Old Aug 21, 2009 | 07:03 PM
nightrunner's Avatar
Mr. Obvious
go 410s. although you will probably not have very good traction on the spray on low-pro 22s.
456s are too much gear with a power adder unless you only run 1/8mile
urdone
Aug 18, 2015 12:17 PM
USMCvet0311
Aug 14, 2015 10:28 PM
ZO6Ted
Aug 12, 2015 07:50 PM
Dirtywhite
Aug 5, 2015 04:10 PM
elpyro89
Jul 28, 2015 05:51 PM
