4.8 build
Old Aug 22, 2013 | 08:48 PM
sloass48's Avatar
Registered User
Default 4.8 build
so im gonna cam, stall, and spray my 4.8. I'm picking up the nos kit this weekend. how big of a cam can i run without changing valve springs, or should i just change them anyways. Kinda looking to run somewhere around a 220/220 cam and a 2500 stall.
Old Aug 22, 2013 | 09:36 PM
oakley6575's Avatar
Springs are based on lift not so much duration. I would put good springs in there if you plan on making any power.
Old Aug 23, 2013 | 09:36 AM
RedHotRodTruck's Avatar
Don't waste your money on a 2500, go ahead with the 3200!!! You will be glad you did.
Old Aug 23, 2013 | 11:01 AM
Blackpanther99's Avatar
Anyhow I would run better springs if your planning on spraying.
Old Aug 24, 2013 | 08:58 PM
sloass48's Avatar
Registered User
should i run a plate or just run a nozzle
Old Aug 25, 2013 | 02:04 PM
02b0wti3's Avatar
Plates work much better than nozzle, I love my N2Outlet plate. Also, I have a Yank SS3600 converter I can hook you up with if interested. Also, do pushrods and springs and not too large of a cam. 220/220 should be fine. I would try to keep it under .600 lift no matter what cam you choose. and a 113 LSA seems to do the trick on the spray.
Old Aug 27, 2013 | 10:43 PM
6789olds's Avatar
Yes do springs stall 3200+
luis_bullz
Sep 8, 2015 03:08 AM
Tigger Welder
Sep 2, 2015 08:17 AM
fastjweb
Aug 15, 2015 10:47 AM
USMCvet0311
Aug 14, 2015 10:28 PM
Cowboy17
Jul 9, 2015 08:22 PM
