2nd fuel system question
Originally Posted by TrickPerformanceProducts
WE can build you a standalone tank, with fuel pump regulator lines, etc. Which vehicle is this for. Tank size roughly 1 gallon or so.. You only need a couple of quarts for a good tank.
Truck Sponsor
699.00. aluminum tank, large filler lid, walbro 255 intank pump, Bypass regulator, all fittings, and lines. You will need to make final electrical connection, and build the final regulator to fuel noid hose. Again the hose and fittings are supplied.
EDIT: tank will be fitted to the truck, a custom set up. NO off the self almost fitting tank.
