175 shot ignition problem
Old Sep 8, 2010 | 11:48 AM
ANGRYGREG's Avatar
Default 175 shot ignition problem
I had a nitrous kit installed and it is not working correctly. It is a zex kit with a window switch, 175 shot on a 408 with an mp 112 making 5 lbs of boost. The tune is good, AFR is good, fuel delivery is not an issue, 60lb injectors and the nitrous kit has a stand alone fuel system from nitrous outlet.
The nitrous works in first gear but in second and third, where there is more load, it starts breaking up at about 4500 rpms
I was told this is an ignition issue and that the spark is being blown out. I put new TR6 plugs in and had them gapped down to 20 and the problem did not go away. I ordered plug wires this morning to see if that is the issue. I don't have the funds to buy new coil packs so I hope it is the wires. From what I have read the stock coils can hold up to a lot more horsepower than I am making.
I was thinking about trying a smaller shot but don't want to have to go that route. Has anyone had this problem? Need some help guys.
This is on a 2004 SS Silverado.
I have been a member for a while and usually just search the forum but i am stumped.
Old Sep 8, 2010 | 12:00 PM
SLOXCAB's Avatar
Fellow OC guy huh? Who's tuning this beast?
Old Sep 8, 2010 | 12:03 PM
Holty's Avatar
Notorious BIG
what do you mean by breaking up? The nitrous stops working or the motor sounds like it is misfiring?
Old Sep 8, 2010 | 12:41 PM
charcold-bowtie's Avatar
Kr or burst knock maybe?
Old Sep 8, 2010 | 12:52 PM
fastrt's Avatar
11 Second Truck Club
ohh no, you got the wrong plugs for that shot and boost. you need a br7ef, and some piming pulled prolly. tr6 will turn into a glowplug and cause it to missfire/KR. hope you didnt hurt it!!!
Old Sep 8, 2010 | 03:33 PM
ANGRYGREG's Avatar
I have been on the dyno 2 times with the nitrous. There is no knock and AFR is good. I swapped the jets this morning from 175 to 100 shot and it is still blowing out the the spark but it is not as bad.
I will try the br7 plugs next if the wires don't help. This was mentioned to me on silveradoss.com
Tuned by Church Automotive testing in Wilmington, LA county
Thanks for the help
Old Sep 8, 2010 | 04:25 PM
SLOXCAB's Avatar
I know churches is mainly an import shop. If you want email justin at blackbear. He's now is SD
Old Sep 10, 2010 | 05:44 PM
ANGRYGREG's Avatar
Put the br7ef plugs in today and new wire's. we lowered the fuel pressure on the stand alone, tested the battery and alternator and put the 150 jets in. The plugs made a world of difference and truck is running much better. It is still breaking up a little bit but nothing like it was. I am going to order some 8's and see what happens.
Old Sep 10, 2010 | 05:50 PM
silverz28camaro's Avatar
try a tr7ix
1_fastsilverado
Oct 11, 2015 11:34 PM
slowswb
Oct 8, 2015 07:27 AM
cousblake11
Sep 9, 2015 06:52 PM
slowswb
Sep 5, 2015 02:27 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
