100hp
Old Sep 29, 2014 | 11:41 AM
turboal1's Avatar
Default 100hp
thinking of doing a 100hp shot on my truck. will i need to retard the
timing ? use colder plugs ? any thing special ? 5.3, camed, dyno tuned
799 heads, DBW, VVT. see sig for info
Old Sep 30, 2014 | 08:47 AM
Nitrous Express's Avatar
Former Vendor
Yes, you will need to either retard the timing (3-4deg) or use higher octane fuel.
For plugs go to a NGK br6ef
Old Oct 1, 2014 | 10:56 AM
turboal1's Avatar
Default 100hp
I run 93oct but can get 100oct. i have TR5 plugs in now. what is the diff
between the EF and EFS plugs ? can i run those plugs on the street
in a DD without throwing a code or fouling up ?
Old Oct 8, 2014 | 08:30 PM
Sixshooter44's Avatar
Not to steal your thread but I have a 4.8 but I want to spray a 150 shot at with a standalone fuel system using C 16. What plugs would you recommend for that. Thanks
Old Oct 8, 2014 | 10:41 PM
TXsilverado's Avatar
You guys need to post mod specifics...bone stock truck, 100-150 is probably fine on stock tune with the right plug and fuel. Sixshooter gave us absolutely nothing to go by.
Old Oct 9, 2014 | 09:04 AM
Former Vendor
TR5 is a projected tip, the br6ef is a colder heat range and a non projected tip plug. No, it will not have any noticeable adverse effects.
There is a lot of spark plug info here.
http://www.ngksparkplugs.com/docs/te...plications.pdf
Old Oct 9, 2014 | 01:15 PM
HawaiianBoyyyy's Avatar
I dropped my timing 6 degress and I'm running a 150 shot. I went with E3 spark plugs as well. Are you doing a direct port or into throttle body?
Old Oct 9, 2014 | 01:17 PM
Jeebalow's Avatar
Trying to learn as much as I can for running nitrous in the future, just thought I'd point out that I have heard horrible things and had a bad experience with e3 plugs. But that was in a SBC. My gf is having some issues with her mustang currently and she is also running e3 plugs. We will replacing them with stock plugs.
Old Oct 9, 2014 | 01:23 PM
I haven't had one problem with them, guess I'm lucky. lol
Old Oct 9, 2014 | 01:24 PM
Heard NGK makes a good plug for nitrous, try those maybe?
