Stage 2 4l60e or stock 4l80e
Old 07-05-2022, 09:21 PM
Registered User
Victor2185's Avatar
Default Stage 2 4l60e or stock 4l80e
I have an 04 silverado with stage 2 cammed 5.3 but my transmission is slipping, I don't know if I should go for a stage 2 4l60 rebuild or just buy a 4l80 with low miles
Old 07-05-2022, 10:20 PM
FFDP's Avatar
Weight your options and how much money you want to spend.
Doing the 4L80e swap requires fab work, wiring, a new driveshaft and first gear will be way different than the 4L60e. If you have aggressive gears like 4.56's the first gear in the 4L80e won't be as bad with the lower power your 5.3 is putting out.
Probably best to just build up the 4L60e if you don't plan on going for bigger power later on.
Old 07-06-2022, 07:02 AM
DuNnO
RDF1's Avatar
Yea depends on future mods..
Is yours a regular cab on stock tire size or a crew cab 4x4 with larger tires?
what size cam?
WedgedS10
02-09-2021 04:28 PM
Hlb7194
02-18-2019 04:38 PM
Bchasse53
04-26-2014 06:59 PM
misfitfsk
10-02-2007 01:18 PM
Quick Reply: Stage 2 4l60e or stock 4l80e
