newb here from Glendale,Az and some answers
Old Jan 30, 2009 | 02:35 PM
blazedchevy69's Avatar
Angry newb here from Glendale,Az and some answers
i would like to know if anyone has had any problems with cam bearings on there 6.0l did a build on one and put a new cam,cam bearings made sure the oil holes were lined up and got 3100 miles out of it,it killed number 3 cam bearing and took out number 4 intake lifter,and the rest of the bearings the back toon the inside lip had an eage on them and front two didnt look to helthy eather need some info thanks
Old Jan 30, 2009 | 02:50 PM
MADS99's Avatar
Welcome from Calif,You may want to go to the GM Performance section with this.Some very sharp members could help you out on this
Old Jan 30, 2009 | 02:58 PM
Default thanks
i tried that already everbody reads it but they dont respond
Old Jan 30, 2009 | 06:59 PM
00Silv4.8's Avatar
wow, never heard that.. Are you sure they were all the right size? also was the cam for the motor? Not trying to cut you down or anything, just curious of facts.
I just reused the cam bearing on my 6.0 I just rebuild and Im not real worried about them.
Old Jan 31, 2009 | 01:48 AM
95 bright teal's Avatar
Welcome, and sorry to hear about the problem, its not common at all. in fact your the first i have heard with this problem.
Do you know what your injector duty cycle is? they have to be beyond maxed out.
Old Jan 31, 2009 | 01:51 AM
A Low Dime's Avatar
13 Second Truck Club
Your sig says lean with stock injectors, shouldnt you be running more then 44lbers?
Old Jan 31, 2009 | 04:12 AM
cam bearings were for a 02 and older no problem going in i thought im used to conventional motors cam was a xer273hr-14
Old Jan 31, 2009 | 04:14 AM
there were at 100% i was going down to get my new tune when it let go i was puttin 44lbs motacs in it
Old Jan 31, 2009 | 08:59 AM
44's will help, 80% is when you want to plan for bigger. I wouldnt doubt the failure is from going lean
Old Jan 31, 2009 | 11:44 PM
thunder550's Avatar
High on diesel fumes
What year is the block?
