2000 Silverado 5.3 swap to LS1
Old Jul 15, 2008 | 08:04 PM
old pops's Avatar
Registered User
Default 2000 Silverado 5.3 swap to LS1
Hello every one I have a 2000 Silverado step side , I want to swap the 5.3 & the L60 trany out. Was told I could go to a LS1 up to a LS6 , but would want to stay in the 2000 to 2004 year of that motor, also going to a L80 trany.
Will the wiring & the computer work on this swap.
Later old pops
Old Jul 15, 2008 | 08:08 PM
venomhp's Avatar
your pcm would have to be flashed, some wires/connectors will be different
Old Jul 15, 2008 | 09:25 PM
TXsilverado's Avatar
your computer and wiring will be just fine. re-use your truck intake manifold/injectors and re-use the 5.3 accessories your currently running. the motor will run ok on your current tune but your best bet is to get a new custom tune for the added cubes. my truck went from 13.88 to 13.26 with the motor swap being the only change. the swap is a direct swap from the 5.3 to ls1. everything will bolt up the same exact way if you re-use the truck intake and accessories. use the truck motor mounts too.
quicksilverado's Avatar
If he uses the harness in the truck, all the connectors will work.
Old Jul 15, 2008 | 11:53 PM
chevyguy7802's Avatar
Welcome to the site and good luck on the swap!
Old Jul 16, 2008 | 01:01 AM
Silverado_13's Avatar
Self proclaimed VILLAGE IDIOT
Where in GA are you at?
zo6freak
14
Oct 18, 2015 06:43 PM
steves86ta
Jul 28, 2015 10:21 AM
04450r
Jul 24, 2015 01:58 AM
Ketis
Jul 23, 2015 12:37 PM
samg430
Jul 20, 2015 10:12 AM
