Some vids for Roger aka the alaska guy :P
Just bs'n around Roge, so I fig I would get you a few little clips.. Have the windows up and down, to give you a idea of the noise with the single 4'' exhaust, the edy muffler.. Some part throttle, even, yes even a little rolling burn out for ya
( next time I will try to get some 55mph smokeys
).. Normal drive with the windows up or down is ruffly 70-83 db's based on that app.. Have to adjust the camera settings for the bright *** light..
Mixed driving - YouTube
Hit the 2 step for ya.. Actually I wanted to scare some kids walking..
Little rolling smokey.. Had to stay good, people out on the roads
note this is a cam'd only 4.8 running 3lbs
LOL. he goes through all that work to get you videos too
I have a mount for my GoPro that is designed to clasp to a bar up to an inch thick. Think I will rig up some way to secure a bar between my two head rests and mount it. Be nice to have a video so I can track what gear, RPM and speed I am crossing the line at. I can never remember to write it all down when at the track.
Yes it does work nice.. I did have a small rubber washer that I used to put under it, to keep down on the shake, but have to make a new one.. Also I took and cut a notch in the mounting plat, bent it so that I did not have to move the seat back forward to get my angle right, if you can understand what I meant..
Yah if you want to spend the 3xx on a go-pro.. If you have a digi cam already it takes about 35mns to make, uses the reg mounting hole on the camera(tri-bi pod mount).. But go-pros are nice. Hope to pick one up soon so I can get good boat, atv action..
Bic Boi
