Can't hook on the street on slicks either: Video
ok for one that burnout was too much for being on the street. you heated them up too much. two, if you load the converter that much of course it's going to spin.
i had my slicks on my truck the other day trying out the nitrous. all they need is a good wipe off on the street and you should be good. my **** hooked letting it roll about 1mph then punching it, 75 shot came on at 3k and the tires held it. maybe it's the caltracs that's helping me also?
http://www.youtube.com/watch?v=du_xBuE6ks4 Hook this homo...
Na your truck sounds good man... You have too much powa
Wearin' da big hat
I can brake stall my truck into spinning the tires
Wearin' da big hat
I would love to work on getting better weight transfer, but I still use this thing as a truck, and drive it every day so it must handle good (i.e. I don't wanna pull the front sway bar or put in weaker springs)
Wearin' da big hat
Also in this video, specifically the in cab one, you can hear what my fuel pump is doing when it gets below 1/4 tank. If you listen closely just after the tires hook up (~7sec mark) that the RPM kinda goes flat, and then starts climbing. It's really annoying and seems to be getting worse. i went and got gas later and put 19 gallons in it, so it was far from empty.
I hear ya, thats the best having a fast truck that actually functions. Maybe this link will help?
http://www.calvertracing.com/caltracs.php
