Cammed Denali first start. 222/226
You have a similar cam in your truck? Thats great to hear. I am still working on the WOT tune and there is a ton of work still to do on it. Where did you notice the biggest power increases and what size stall do you run? Where do you shift yours? To be honest I kind of expected to lose more off the bottom and pick up more of a mid range hit, but like i said, theres still a lot of work to do with the tune.
I'm trying to nail down which converter I'm going to go with rigth now. At the top of my list at the moment is the Circle D 278mm 3000-3200. Do you have any suggestions?
What body style is your truck? 4x4 or 2wd? have you run it at the track?
I can't believe we have basically the same EXCACT set up (motor wise) and I never knew it.
Its an ecsb 2wd. It went 13.73 with the stock internal lq9 and yank pt 3600. I need some tires to make it worthwhile to track it with the cam, because thr above run was on street tires and abysmal 2.x 60'
I think that 3200 will work great. It will be a great combo for the street and should work well at the street.
Running a 220/226 .556 .570 on 114+4 in my LQ9 in sig. and it's very streetable, not much power loss down low, and pulls like a raped ape past 5000rpms. My best NA was 13.2~ on 2.2 60foot at 102mph. On a 125 shot I trapped 112mph same 60 foot, spun all the way down track and ran a 12.92. What's the lift on your cam if u don't mind?
Thanks man, its spot on for what I asked for. Lope without being obnoxious at all. If I had a louder exhaust it would definitely be more noticable, but still not absurd. This truck is too nice for absurd... and its still a daily driver.
Thanks guys,
222/226 114 LSA cam idle clip - YouTube
I will get a cut out eventually... that should sound pretty beast without cats
