MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
7.62@92 6.2L Z71 Vid
Old Feb 2, 2010 | 12:02 AM
  #21
BadManLS1's Avatar
12 Second Club
Originally Posted by dlt76028
what all did you have to do to put the 6.2 in a 04?
I got rid of the VVT cam and cam gear, put an ls2 timing cover with a gen 3 224 cam and ls7 cam gear. I'm using the Lingenfelter Reluctor box 58 to 24 tooth. Also using a map, cam, and knock sensor extension harness from Lingenfelter. You also have to get the injector conversion adapters from gen 3 to gen 4 style injectors and you have to use the Torque Rush X-link for the TB to open 100%.
Old Feb 2, 2010 | 12:06 AM
  #22
A Low Dime's Avatar
13 Second Truck Club
Are you having any problems with that Lingenfelter box? I have read a lot of people have problems with them.
Old Feb 2, 2010 | 12:11 AM
  #23
BadManLS1's Avatar
12 Second Club
I thought I was when I first did the swap. I sent it back 3 times to Lingenfelter...but it turned out it was the tune. Took it to a different tuner and it has been fine for over 5 months now.
Old Feb 2, 2010 | 12:13 AM
  #24
A Low Dime's Avatar
Interesting.
When are you spraying?
Old Feb 2, 2010 | 12:18 AM
  #25
BadManLS1's Avatar
12 Second Club
Interesting.
Trying to as soon as it hooks, but as you can see in the vid it was spinning in 4hi...the track prep sucks at DMP...I'm going to a 1/4 mile track soon that hooks good (SGMP).
Old Feb 2, 2010 | 01:00 PM
  #26
Bad_Apple's Avatar
You and Pewter53 need to run on the spray yall are neck and neck.
Old Feb 2, 2010 | 01:46 PM
  #27
BadManLS1's Avatar
12 Second Club
He traded that truck 6 months ago for a 2000 z28. Its in south fl now. His best was a 7.59@89 1.65 60ft on a 175 shot.
Old Feb 2, 2010 | 10:18 PM
  #28
KDavis04ss's Avatar
great times N/A in my opinion. i would like to run you next time were in douglas after i get a cam and tune. should be a good race.
Old Feb 2, 2010 | 11:03 PM
  #29
stock48's Avatar
9 Second Truck Club
Originally Posted by 00ChevyScott
I surprised it only ran an 8.2 N/A...
His truck runs better than you think. There is a HUGE difference between a 4x4 running in 4wd vs a 2wd. It's not just the extra weight its the parastatic loss of the Tcase, extra diff, cv joints, u joints etc combined with the front and rear end being binded together. The truck is almost in a bind on dry pavement when 4wd is engaged. AWD is alot more forgiving due to the viscus coupling that eases the tention between front, and rear diff.
My truck picked up 3mph in just the 1/8 mi just by running in 2wd. Also was with an unspooled launch.
Old Feb 3, 2010 | 02:45 AM
  #30
BadManLS1's Avatar
12 Second Club
Thanks man. I saw you run a couple sunday's ago at DMP. Whats the specs on the cam?
