MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
4.8L Turbo 76GTS: MSD 2-Step Video
Old Jan 21, 2011 | 09:04 PM
foose04's Avatar
Default 4.8L Turbo 76GTS: MSD 2-Step Video
Well after some advice, got the new MSD installed tonight in about 1 hour. Here's a 3500 RPM stall. First is 40% throttle, then a couple 100% one's. Looks to be making around 3-4 extra PSI at the same RPM. This is to much for the street as you can tell the 305's wont hold, but I'm hoping @ the track the hoosier's will.
http://www.youtube.com/watch?v=ZS5tY...&feature=feedu
Old Jan 21, 2011 | 09:35 PM
Gadgetized's Avatar
I have been waiting to see some videos of this truck with the new turbo. Sounds real good. I bet that thing is going to be a lot of fun. Makes me wish Joe Gibbs trucks came with a turbo instead of a charger.
Old Jan 21, 2011 | 09:47 PM
quicksilverado's Avatar
Hang on at the track, because you are gonna go for a ride.
Old Jan 21, 2011 | 10:54 PM
Mangled03gmc's Avatar
Baltimore Whore
Sounds good. What verter are you running in that truck??
Old Jan 22, 2011 | 03:10 AM
Most Hated's Avatar
nice.
Old Jan 24, 2011 | 04:44 PM
built408's Avatar
Don't show this to your converter guy... It's not great on the stator to stand on the brake and just dump the throttle. Just FYI...
Old Jan 24, 2011 | 07:03 PM
shawnss's Avatar
Sounds bad ***. I bet it will help spool.hope it holds at the track. So is this msd 2 stepthe plug in play model? I think the part number I'm talking about it 8733? If not which one do you have?
Old Jan 26, 2011 | 05:58 PM
schino's Avatar
sounds mean as hell. although there would be no benefit to doing this on the street because of traction itd be great lining up next to someone and hitting that. do you have a brake in the trans? obv wasnt being used in this vid if you do just cant remember if you have one along with the mvb
Old Jan 26, 2011 | 09:33 PM
sprayedenali's Avatar
probably the coolest sound EVER!!!!!!
Old Jan 27, 2011 | 03:23 PM
foose04's Avatar
I do have a T-Brake Shino, should have it up in running along with the 2-step soon. Shawn this is the MSD 8733..
Built408 wouldn't it be just as hard on the converter using a trans-brake and stalling the converter up at the line?
