Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
will these fit?
Old Feb 10, 2011 | 12:02 AM
Goose33's Avatar
Default will these fit?
i have a 98 s10 DD..im goin to be turning it over to my dad soon and i found a set of Torque Thrust Wheels (which is mine and his favorite rim) and the guy has them cheap but they are 17x9.5 rims thats all he knows on them..will they fit under my truck with stock stance? he had them on a mustang..thanks
Old Feb 10, 2011 | 11:54 AM
LSGUNSS's Avatar
formerly 2000blackcamaross (6-25-2013)
The Mustang and S-10 have different bolt pasterns, S-10 5 x 5.75 and Mustang 5 x 4.5. So you would need a wheel adapter to get these to fit. The good news is you would need the wheel adapters anyway to get the right offset/backspacing. 9.5" wide wheels should not be a problem fitting in the rear of the truck because I am running a 10.5" wide wheel on my S-10 with a 2.5" adapter. The fronts should work with stock parts and an adapter. If it is lowered (I know you said stock stance) it might be tough because some wheels will hit the tie-rod end.
Hope this helps
Old Feb 10, 2011 | 12:47 PM
Goose33's Avatar
Sweet man that makes sense...I appreciate the help..might look into it then
Where u get ur wheel adaptor
Old Feb 10, 2011 | 03:47 PM
LSGUNSS's Avatar
I will have to send you a pm because their not a sponsor on here.
Old Feb 11, 2011 | 01:07 PM
turboal1's Avatar
Default ZQ8 Wheels
the S-10 extremes had a 16x8 with a 5" back space. hope this info helps.
btw i had 275x50x16 tires on the rear with no prob and 255x50x16 front.
Old Feb 11, 2011 | 07:50 PM
Goose33's Avatar
Yeah thanks man
If that's your xtreme it's nice!
simman22
Jan 21, 2017 10:27 PM
FlowmasterMufflers
Nov 24, 2015 01:00 PM
SloSVO
Sep 12, 2015 06:56 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
LSX-81-SIERRA
Sep 5, 2015 02:51 PM
