Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
"Project LS10"
Old 02-19-2011, 02:40 PM
  #31
redneckK20's Avatar
Cool build, I've always wanted an LS powered S10. I grew up in Mexico, MO, small world I suppose.
Old 02-21-2011, 07:36 PM
  #32
formerly 2000blackcamaross (6-25-2013)
LSGUNSS's Avatar
Check out www.midwestce.net it is a local car site.
Old 02-21-2011, 07:50 PM
  #33
2000chevysilverado's Avatar
Its well worth having one they are fun but a real pain in the a$$ to work on and its sometimes more touble than anything but heres a couple of pics on how mine looked when I had it, but it was well worth it when mine looked like a sleepr
Attached Thumbnails "Project LS10"-img_0035.jpg   "Project LS10"-img_0036.jpg   "Project LS10"-img_0004.jpg
Old 03-01-2011, 04:54 PM
  #34
LSGUNSS's Avatar
UPDATE:
I picked up some LQ4 rods and pistons with 20,xxx miles that I am going to use with new rings and barings.
I also hit up summit for some ARP fasteners. I'm still waiting for the Crank bolt but I did get Head bolts, Rod bolts, torque converter bolts, and Flex plate bolts.
Old 03-01-2011, 10:00 PM
  #35
SPAM HUNTER
2005 Silverado's Avatar
why not get some ls2 rods?
Old 03-01-2011, 10:05 PM
  #36
LSGUNSS's Avatar
I will make this a 408ci in a year or two after I work all the bugs out of this "stockish" 6.0L
Old 03-16-2011, 09:01 PM
  #37
LSGUNSS's Avatar
It was nice today (65ish) so I did a little work in the garage after work. I bought a Truck accessory alternator and Power Steering bracket and started cutting on it tonight. I am going to run the LS6 intake and to do that I have to cut...
Before:
After:
Then I started to make a template for the base of the relocation of the Idler pulley. I am going to get a short piece of pipe, weld it to the base and tap it for the pulley.
Old 03-25-2011, 11:43 PM
  #38
L$X$10's Avatar
i cant wait to have a single cab step side 6.0 s10...keep it up..looks good
Old 03-28-2011, 04:06 PM
  #39
LSGUNSS's Avatar
I built a idler pulley relocation bracket...
I had to grind the aluminum down flat so my bracket would work
I picked up some LS1 heads to bump the compression up to around 10.5:1. I will have them ported if the local guy still does it. I had him do a pair of 241's on my Silverado and they flowed some good numbers for a "street port".
I bought a flex plate, Catch Can,:
I found this that I had in my fullsize and it works perfect in my S10 so I might use it or I might sell it. I might sell the trans temp gauge too.
Old 03-29-2011, 03:47 PM
  #40
LSGUNSS's Avatar
I painted the brackets today:
Quick Reply: "Project LS10"
