Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
popping in the frontend
Old Jan 3, 2009 | 02:00 AM
silver-mod-o's Avatar
Hunt&Fisherator
Default popping in the frontend
Well I've got a pop coming from my driver front corner. I've jacked the truck up, nothings loose, in a bind, or out of place.
The trucks been lowered 3/3 with coils and angle cut blocks. It popped sometimes before but does it more and more now... Nothing feels off about it when driving either... Just a noise. Anybody got any clues??? Balljoint? bushing?
This is the 2000 S10 in my sig...
Old Jan 3, 2009 | 05:28 AM
LowBlack99's Avatar
I believe there is a TSB on it? OOPs just noticed it was for a S-10. I had a 96 Tahoe lowered with springs and it made a bad pop/rattle when going over bumps when the suspension loaded/unloaded. Turned out to be the seal in the brake calipers where the pins went in were wore out and the caliper rattled. Might check that?
Old Jan 3, 2009 | 06:43 AM
cheyenne383's Avatar
TOWN CRIER
Upper ball joints wear out quick on S10s, especially lowered ones, but that should be easy to check with a floor jack. Also check the control arm bushings and pitman/idler arms. Most of the other joints you would feel, not hear.
Old Jan 3, 2009 | 08:00 AM
Hunt&Fisherator
I cant find anything loose or anything with any slack in it.... I have never, not been able to tell whats wrong by taking off the wheel and shaking some stuff around LOL
Old Jan 3, 2009 | 03:34 PM
sixltrbtr's Avatar
Bring it by and let me look at it next chance you get.
Old Jan 3, 2009 | 07:46 PM
Low_S-10's Avatar
on my s-10 i had to add a sping washer where the hood hinge bolts together, there is a tech bulletin. also check the idler arm cause when i got the truck it made a little noise but it went away after i greased the front end
Old Jan 4, 2009 | 12:10 AM
01cherryreds10's Avatar
Check your dustshield, it may be hitting the control arm. Here's some pictures if you wanted to trim it down and stop any noise that may be caused by the shield.
Old Jan 4, 2009 | 08:19 AM
Hunt&Fisherator
Well I noticed on the home this morning that it does it 99% of the time on the suspension rebound when its unloading. Even leaving a light, if the nose comes up at all it pops... Big swooping or rolling bumps made it so I noticed when it was doing it.
Old Jan 4, 2009 | 03:02 PM
Possibly the shocks if it only does it on the rebound?
00loudchevy
Dec 3, 2015 05:54 PM
drummer0415
11
Oct 24, 2015 08:16 PM
Vortec350ss
Oct 10, 2015 09:11 PM
97_ek
Sep 23, 2015 09:16 PM
Lthompson
Sep 15, 2015 07:55 PM
