Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
2012 colorado 5.3....?
Old 02-19-2013, 08:27 PM
djorgensen3's Avatar
Default 2012 colorado 5.3....?
I would like to upgrade the cam in my truck so it has the power a v8 truck deserves. It also needs to be able to pass emissions here in AZ. It is a 4x4 crewcab with stock size tires for now. I have modified the stock airbox and put on a large diameter single exhaust. I will also be installing headers and plan on a blackbear tune in May when they come to Phoenix.
Old 02-19-2013, 10:08 PM
LsXblaze's Avatar
Id go with a old man cam... comp cams has truck cams take a look at these two. 54-450-11 or 54-452-11. or if you want to go with a little more aggresive look at the 54-412-11. i think either of those would work well with your setup with a stock converter and a tune. you would also want to upgrade valve springs as well
Old 02-19-2013, 10:50 PM
Chevy_King1500's Avatar
all three of those cams will work great in your truck.
what kind of emissions test do you have to pass?
congrats on your first post. lol
Old 02-20-2013, 02:43 AM
gamble686's Avatar
In AZ it's just a quick OBDII check a well tuned vehicle will never fail even with no cats. I would suggest a 212/218 or 216/220 cam. Great power proven to work well without the aid of a stall.
Old 02-20-2013, 10:17 AM
Anyone of you know what the factory colorado cam specs are so I have something to compare to?
Old 02-20-2013, 11:39 AM
gamble686's Avatar
5.3= 191/190 .457/.466 114 lsa
You can also easily get a custom speced cam from a number of sources who can set you up with the perfect cam for your goals and build.
Old 02-20-2013, 12:25 PM
LsXblaze's Avatar
i agree with what gamble686 said... ive called comp cams a few times and talked to different people each time and each person specd out a different cam for my setup.... i have been searching for the "right" cam for about a month now and finally decided on one. call different sources and get cams specd out and take your time.
Old 02-20-2013, 01:20 PM
TXSZ66AVLANCHE's Avatar
Cam specs on the 07+ 5.3 is 193/193 .480/.480 114LSA -3*
Old 02-21-2013, 10:26 AM
Okay I have started an email conversation with Trevor at Texas Speed. I want to make sure about VVT and AFM. I know the Colorado has VVT but I am not sure about AFM. Anyone know for sure whether or not this truck has it?
Old 02-21-2013, 12:34 PM
VVT is a cool feature! Adjust the valve timing so you can have power up top, and down low, Id keep that. AFM....get rid of it.
Quick Reply: 2012 colorado 5.3....?
