Manually selecting 2 0r 1
Old Nov 17, 2006 | 05:31 PM
Kingpimp's Avatar
Default Manually selecting 2 0r 1
My roommate has a 2001 Ford Ranger with an AT. I dropped the gear selector one positions too many into 2nd versus D. The truck felt gutless until I put the selector back into D.
This isn't a specific truck problem, I am pretty sure every Ford I have driven is like this. Why is that? What is happening?
Old Nov 17, 2006 | 05:34 PM
LesPaul's Avatar
ummmmmm...... you were starting from 0 in second gear.... that adds up to gutless
Old Nov 17, 2006 | 05:52 PM
Kingpimp's Avatar
It's an auto, shouldn't it select first regardless of where the gear stalk is?
Old Nov 18, 2006 | 03:30 AM
LesPaul's Avatar
NO...... if you select second it will start in second..
Old Nov 18, 2006 | 06:04 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Te transgo kit makes it stay in 2nd. At least it did for me.
Old Nov 18, 2006 | 12:36 PM
Kingpimp's Avatar
Why would Ford design it like that? To start in second from a stop.
Old Nov 19, 2006 | 11:42 PM
gun5l1ng3r's Avatar
because the first gear is so short
Old Nov 19, 2006 | 11:45 PM
LesPaul's Avatar
mine start in second if its slected and i dont have a shift kit
Old Dec 4, 2006 | 05:45 PM
Barras's Avatar
I beleive they are designed like that with slippery roads in mine....so it wont break the tires loose from a standstill. Most every truck is like that i believe.
Old Dec 4, 2006 | 06:16 PM
blake2kz71's Avatar
me too but if you stomp it when 2nd is selected it will roll then gear down to first. also when first is selected sometimes it will shift by itself then other times it will just hit the rev limiter until i shift.
