Factory Pulley on Lightning?
6lbs can be very safe with a good tune. I would recomend going to the ngk TR6 plugs and a 170 degree stat with the 6 though. These truck can handle quit a bit of power, what they do not like is to be run hard for long periods of time. The eaton builds up a lot of heat.
Guest
Posts: n/a
if you're adding a 6lb lower to the stock upper, you'll definitely need a retune as well as a set of NGK TR6's. as mentioned, don't try to do back to back pulls since the Eaton builds up a tremendous amount of heat and you are prone to issues from the heat soak
SlvrSierra4.8
Oct 1, 2015 09:39 PM
