boost acuator mod
Old May 7, 2006 | 07:13 PM
javman's Avatar
Default boost acuator mod
i did the boost acuator adjustment and boost by pass today and my peak boost in second is only about 8psi it seems to jump to about 6 then very slowly climb. i am running a CIA with stock pullies and a stock tune. previously i was peeking about 9 to a little over 10psi with just the CIA. i folowed the directions on svtp for the accuator adjustment and the instructions on rpm outlet's site for the by pass. the boost guage seems more responsive to throughtle in the midrange but the seet of my pants feel seems to be lacking it feels less responsive (from a dead stop it will no longer spin the tires through second they stop when it shifts) but from a role of about 40 it feels a little better than before.
will the bypass scew the reading for the guage because it is T'ed into the line or can the very humid air today in kc be throughing me off?
i did not get any warning lights so i think i did every thing right.
i will drive it this way this week and see if it seems any better during daly driving. Hopefuly it wont rain and i can take it to the track and see what it wil do.
Old May 7, 2006 | 08:27 PM
203Cree's Avatar
It's more than likely just the air today. Mine wasn't acting right today either.
Old May 8, 2006 | 12:59 PM
javman's Avatar
thanks that makes me feel better, i was hoping i didn't f anything up.
at least it was only about a 10 minute job for both items so if dose contenue acting up it is at least quick fix
Old May 8, 2006 | 08:07 PM
BC Lightning's Avatar
well you can take the boost by pass mod of, that only really works for 99-00, 01+ is computer controlled, asked Jim D. in 2002 about this for my 02 L and he just laughed
Old May 12, 2006 | 12:52 PM
javman's Avatar
is this the mod you are talking about
http://www.svtperformance.com/forums...d.php?t=225119
it seems to work but i dont know if it does anything more make the boost guage more responsive it will now come out of vacume with less input on the gass peddle but i didnt feel any difrence at WOT
Old May 12, 2006 | 03:00 PM
rgcbshrty's Avatar
The mod won't do anything for performance. It will keep the computer from pulling boost under certain situations.
The mod in question bypasses the computer controlled solenoid. The term boost bypass is very misleading. The bypass valve isn't being bypassed and no boost is bypassed with the mod.
All the L's use the same computer controlled solenoid. While under boost and when needed the computer allows the solenoid to apply vaccuum to the bypass valve. In turn causing a "dumping" of boost. Without the solenoid in place, the bypass valve will continue to function as intended. Opening under vaccum and closing under boost. No harm will come to your engine.
Old May 12, 2006 | 05:21 PM
203Cree's Avatar
You're spot on for the boost bypass mod. If it was me I'd have saved the money and just unplugged the solenoid.
What he's talking about tho is the adjustment you do to the actuator rod it's self. It will help you see boost a bit quicker.
Old May 14, 2006 | 10:52 PM
javman's Avatar
Drove it this week and it is was defanitly the air causing the bad performance. On the few good days this week it was acting much better than on the day i first did the adjustmet. also it is defanatly getting into boost quicker under part throughtle. Good for now but may suck come winter.
GXPJAY
Feb 13, 2022 08:15 AM
RoidedSS
Aug 11, 2015 11:51 AM
JordanH
Aug 8, 2015 07:59 PM
black6spdz
Jul 16, 2015 01:32 AM
ALynch
Jul 6, 2015 09:49 AM
