Wtf...
Old Apr 15, 2011 | 09:22 PM
06murder's Avatar
Default Wtf...
i got an 2000 5.3, got it frm the junkyard.an looked at it the manifold bolts broke in the damn head...i tried the easyout **** but its not working =,so can some tell how to get all 8 of the bolts out...
Old Apr 15, 2011 | 09:55 PM
Mangled03gmc's Avatar
Baltimore Whore
Are the bolts broke off in the head or flush with them??
Old Apr 15, 2011 | 10:09 PM
06murder's Avatar
one flush n the other 7 arnt...very frm 1/8'' to bout a half inch...
Old Apr 16, 2011 | 12:13 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
for the ones that aren't flush spray on some penetrating lube and carefully try to get them out with some vice grips (works very well).
For the flush one, you need a machinist with an EDM to melt them out (or they might chisel them out and rethread)
Old Apr 16, 2011 | 12:27 AM
Spoolin's Avatar
GFYS and STFU
Ouch...Too bad junk yards don't have warranties!!
Old Apr 16, 2011 | 12:30 AM
04Burban's Avatar
Looks like a good reason to get new heads to me lmao :smile:
Old Apr 16, 2011 | 08:33 AM
bennettracing's Avatar
Drill a 1/8 hole in the center of the bolt then use a dremel with a tungsten bit and spilt the bolt into 3 and stop short of the threads. I did mine with the head still on the truck not a big deal pretty easy hope this helps.
Old Apr 16, 2011 | 09:52 AM
06murder's Avatar
i would of had an warranty but since its not going in a 2000 truck, they wont warranty it..butt really its in good shape rear main seal has no signs of a link...heads like good side them exhaust bolts but i try again n c...wish me luck
Old Apr 19, 2011 | 10:25 AM
00buckshot's Avatar
Its not too bad of a deal man, I know it can get aggravating tho
Old Apr 19, 2011 | 10:35 AM
budhayes3's Avatar
PT's Slowest Truck
+1, and you could try drilling the flush bolt out, starting small, getting dead center, and being very patient. Keep stepping up the drill bit until you can basically pick apart the remaining thin layer of bolt thread, being careful not to damage the head. I've done this many times, you have to be careful and it's tedious, but it works.
