is it worth to go from 5.3 to 6.0 in my case?
Old Oct 21, 2011 | 10:47 AM
walledition's Avatar
so far so good, i´ll keep in mind the heads and the injectors and if possible a walbro 255
anyways the seller is a good friend and will let me take it for a check up see if the motor is all good
6.0 and 4l60e will need no adapter to work together?
Old Oct 21, 2011 | 11:43 AM
jerrynaranjo08's Avatar
im currently doing the same swap in my 02 yukon...got an LQ9 going in it...hopefully i can finish it this weekend...
Old Oct 21, 2011 | 12:02 PM
i wish i was that far ahead, could u give me more details on your build?
Old Oct 28, 2011 | 10:48 AM
its pretty simple swap...some things are different like coil packs...intake is a little different, looks the same but lq9 intake has an egr valve and my current 5.3 intake doesnt have it in the same place not sure what to do here...any input anyone???
Old Oct 28, 2011 | 05:52 PM
1Bear's Avatar
Just use the intake manifold from the 5.3L, it will not suffer a performance loss, as the intakes are the same outside of the different emissions equipment and possibly not having the nut inserts for a cable throttle bracket on the LQ9 intake.
Old Oct 31, 2011 | 02:05 AM
slowec's Avatar
Your trans will fit fine too. just use the flexplate off the old engine.
P.S. Its always worth it to add 100 ft pounds of torque!
Old Oct 31, 2011 | 02:39 AM
lady3bglover's Avatar
Why would you have to swap the coils? I'm using my 5.3 coils on an L92/Ls2 conversion. I did up the injectors to new 44's, and I'm still using the 5.3 intake.
Old Nov 6, 2011 | 11:57 AM
thats what i mean...i need to keep my 5.3 intake, coils, and all my accesories from my 5.3 to the 6.0
ferrellrooster
Mar 6, 2025 03:22 PM
JordanH
Aug 8, 2015 07:59 PM
05GMC4.8
Aug 7, 2015 09:55 PM
steves86ta
Jul 28, 2015 10:21 AM
justuc
Jul 24, 2015 11:52 PM
