Will this work?
Old Aug 29, 2007 | 07:14 PM
2001AntiVenom's Avatar
Default Will this work?
I have a 2001 z28 and im putting a new motor in it. My friend has a 2004 chevy truck with a 5.3 in it. Will my patriot stage 2 heads, comp cam, ls6 intake, stock throttle body, and mass air work on his truck. with the conections on the wires and all for the mass air and throttle body?
Old Aug 29, 2007 | 07:23 PM
nightrunner's Avatar
Mr. Obvious
the heads and cam will work but not sure if they are optimal for a truck setup, any cam specs??
the ls6 intake will take some work, no need for swapping the ls1 tb for the truck tb. no need to swap the MAF sensor unless its a lingenfelter 100mm version
Old Aug 29, 2007 | 07:37 PM
the cam is a comp 232-234 595-598. i know its a pretty big cam. he might just go with my stock cam. how much better is a stock ls1 cam than a stock 5.3 cam?
Old Aug 29, 2007 | 07:45 PM
Mr. Obvious
a little better but not worth swapping IMO, you could probably trade cams with somebody for a smaller one that would work better, a 224 or smaller
Old Aug 29, 2007 | 07:56 PM
alright thanks. do you think its even worth him putting the heads on then?
Old Aug 29, 2007 | 08:31 PM
Truck 85mm MAF is larger than the stock z28 unit.Everything else will work with his 5.3,you need to check to see what size chambers the stage 2 heads have to see if you'll need to mill them to maintain the 5.3s'compression ratio as it has dished piston vs. the flat top pistons in the ls1 motor.
Old Aug 29, 2007 | 08:35 PM
StrokerAce03's Avatar
I thought the truck TB was 78 mm?
Old Aug 29, 2007 | 08:45 PM
Mr. Obvious
yes but the MAF is 85mm
Old Aug 30, 2007 | 03:44 PM
alright thanks guys.
Old Sep 1, 2007 | 06:02 PM
IMD's Avatar
IMD
Banned
wanna sell that cam?...lemme know.
shawn96gmc
May 17, 2016 04:15 PM
Stainless Works
Apr 10, 2016 04:34 PM
Stainless Works
Aug 4, 2015 12:56 PM
atxlt
Jul 20, 2015 11:06 PM
Nimoryan
Jul 5, 2015 03:50 PM
