will this work?
Old Jul 6, 2006 | 12:45 PM
seeyaa's Avatar
Default will this work?
well guys i justed ordered some 41" HEAD gaskets and im was woundering if this will work with a gt2-5 222/222/ 566 566. I know i could do the whole clay thing but im trying to save time. Also will a 7.400 push rod work.
Old Jul 6, 2006 | 01:57 PM
custom 68's Avatar
I am going to use the same cam and was thinking about milling the heads slightly to get more compression so I am wondering the same thing. Mine is a 5.3
Dave
Old Jul 6, 2006 | 05:37 PM
Yelo's Avatar
I believe that's an .041" gasket...a 41" thick gasket might drop compression just a tad
You will have no problems with the valves touching the pistons until you get to the ~.610" lift range with that gasket....
Old Jul 6, 2006 | 06:52 PM
seeyaa's Avatar
thanks sorry about that
Old Jul 6, 2006 | 10:13 PM
litreddevil's Avatar
Banned
Yelo is right i have 216/220 witch is 525/532 with 1.85 rockers that gives me around 579 lift and when i did the clay i still had 110 ths till valve hit piston and that is with soild roller lifters
Old Jul 7, 2006 | 12:31 PM
Zick's Avatar
Should work, I'm running a TR230/224 .575/.563 111 LSA w/ a .040" Cometic head gasket.
Old Jul 7, 2006 | 02:00 PM
custom 68's Avatar
what kind of compression changes are seen with either slight milling or going with the thinker gasket? Is this worth the changes from a performance stand point?
Dave
Old Jul 9, 2006 | 06:45 PM
seeyaa's Avatar
what cr will these gaskets give me. also what pushrod lenth do i need with that cam
shawn96gmc
May 17, 2016 04:15 PM
Stainless Works
Apr 10, 2016 04:34 PM
Stainless Works
Aug 4, 2015 12:56 PM
atxlt
Jul 20, 2015 11:06 PM
Nimoryan
Jul 5, 2015 03:50 PM
