Who Makes THE Best CNC Ported Heads
Old Dec 3, 2009 | 11:08 PM
Pontiac Derek's Avatar
Default Who Makes THE Best CNC Ported Heads
I'm buying heads/rotating assembly/ect tomarro and i'd like some help, Who is Making the very best Heads out there? I want to make over 500hp with my 383 Iron LS Truck engine, i was thinking 215cc Trick flows, AFR's? Also Is Anyone getting more than a 40hp jump in power after a head swap? what heads?????
Old Dec 3, 2009 | 11:12 PM
LS1TRUCKGUY's Avatar
give WCCH (west coast cylinder heads)a call. they are a sponsor>>>>>>>>>>>>>>>>>>>
many people on here have used them and are extremely happy with what richard has suggested
Old Dec 3, 2009 | 11:15 PM
Black'Rado's Avatar
if heard good things from air flow reaserch....no first hand experince though.
Old Dec 3, 2009 | 11:30 PM
GMCtrk's Avatar
Trickflow, in my opinion. This is an aftermarket head casting and is of superior strength to a GM casting, a big plus if you ever go to forced induction. Also, they have a 13.5 degree valve angle which really helps to boost low to mid lift air flow and increase piston-to-valve clearance if you are using a bigger camshaft. Apples to apples on a 427, the trickflow 235cc heads outpower ported LS7 heads throughout the powerband. This goes to show you that the cathedral port heads can outdo GM's absolute best square port factory CNC'd head.
AFR is also in the running, but their heads seem to be of older R&D/technology than the Trickflow stuff. The downside to the trickflow heads though is the necessity of aftermarket roller rockers.
Old Dec 4, 2009 | 12:12 AM
GMCtrk thats what i am thinking as well, Trick Flow really seams to Have it Down Pat with the LS Heads, AFR was Beat in a back to back a while ago and they are more expensive than the tfs heads! And on there new 205cc head 300cfm, 58cc chambers you can run the factory rockers so i think its coming down to which TFS head, I Definately want Aftermarket castings!, Will the 225-235 head bolt on a 3.905 bore? i understand the valve shrouding issue
Old Dec 4, 2009 | 12:14 AM
thanks! does he have a head that will decimate the tfs and all the others? just kiddin!
Old Dec 4, 2009 | 12:15 AM
GMCtrk's Avatar
I believe with a 3.905 bore you'd be relegated to the 215 cc Trickflows. I'm pretty sure the 225s are for 4" bore minimum. I think hands down the way to go with the trickflow's is the 220 cc "as cast" heads. They are $600 cheaper than the CNC'd 215's and on a back to back dyno they are only down 8-10 rwhp I believe.
Old Dec 4, 2009 | 12:27 AM
hmmm, sounds good man, thanks for the info, i think its gotta be the 215's for sure though, I'm also trying to get the new LSXRT intake so it will be interesting to see what numbers she pulls, i'm thinking 228-232 .600 112lsa cam and 11.3:1 comp so maybe i'll see 400+ at the wheels!
Old Dec 4, 2009 | 12:30 AM
GMCtrk's Avatar
there have been several 5.3s posted on here that pushed 400 rwhp with CNC ported 5.3L castings. So I have no doubt 400 is a possibility if you take that route.
Old Dec 4, 2009 | 01:08 AM
caddy03pimpin's Avatar
Trick Flows are the ****.. Bad *** PROVEN heads!
